22r idle issues?!?
Old Apr 3, 2015 | 10:01 AM
4Runnerfreak89's Avatar
22r idle issues?!?
Just finished rebuilding my 22r LCE rebuild kit, LCE headers, LCE single plenum intake manifold, weber 32/36 carb
The truck ran beautifully for a week or 2 then all of the sudden my truck idles high and then low and dies! I'm not sure what to do im new to mechanics I got the truck to learn so please be kind I need all the help I can get?!?
Old Apr 5, 2015 | 07:11 AM
thefishguy77's Avatar
So it will start up idle high then low then die? Can you keep it running? Hold the throttle open a bit? The more we know about the truck what it's doing did it do anything funny before it stared acting up? The better it helps us help you. I dot know much about the carbs on these trucks but is it possible that you have a sticking cable somewhere? Do you have a vacuum leak on the intake? Spraying starter fluid to find possible vacuum leaks works well. When the engine rpms climb quickly the area you sprayed has a vacuum leak more than likely. Basic things I would check for are electrical connections. Plugs, Coil, All your grounds and any wiring you moved around. These wires are old and brittle. Fuel filter? Broken/leaking Fuel line? Dirty clogged fuel line. Maybe dirty lines and need to clean the tankard or pump filter? Blow out the fuel lines? Clogged jet in the carb? Sticking float? Choke? Just random thoughts and ideas. Hope this helps
Old Apr 5, 2015 | 09:22 AM
So I actually figured out the issue it was the igniter and new spark plug wires, I assume I kept dieing because the engine wasn't recuevung enough spark to run properly
Old Apr 5, 2015 | 09:20 PM
Awesome glad you got it figured out.
Old Apr 6, 2015 | 06:32 AM
58rennur4's Avatar
Awesome news, sorry I could not help the original question but it is good news to hear you are burning fuel again
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
cars-guy
Jul 11, 2015 07:51 PM
