22re Cylinder Head Block / Bypass - Whats it called?
Old Oct 24, 2009 | 07:19 PM
redwolf3's Avatar
Hey Guys-
I need help identifying a part on my '85 22re Cylinder Head. This is on the rear of the Cylinder Head:
I'm really trying to figure out what its called so I can figure out the proper way to seal it back up and the proper torque for it (I removed it from my old head). I'm assuming I can just use some Water Pump Sealant since it appears to be some sort of coolant bypass, but wanted to make sure.
Thanks!
Old Oct 24, 2009 | 07:28 PM
crawlerjunkie's Avatar
i don't know what its called but there's a gasket for it in every head job Ive done. as for torque i just tighten it evenly all the way around.
Old Oct 24, 2009 | 07:29 PM
Kiroshu's Avatar
EGR bypass i believe.... i don't think it has a name..... if it did i think its called cylinder head rear plate...............lol
Old Jun 14, 2010 | 10:40 PM
MortonPhotographic's Avatar
Yup, doin' mine now and it isn't even mentioned in the FSM, but there is a diagram of it in the page 63, # 10 photo in regard to the air injection manifold, which I think is the pipe bolted to it.
The Chilton's manual does call it a Cylinder Head Rear Plate.
I can't find a torque spec on it anywhere, Google actually lead me back to this site which is where I usualy look anyway!
Old Jun 15, 2010 | 06:34 AM
4Crawler's Avatar
It is the cooler for the exhaust gas coming from the exhaust ports to the EGR valve (called the EGR Cooler in my '85 FSM).
Old Jun 15, 2010 | 11:38 AM
redwolf3's Avatar
In the FSM, there are "default" torque specs for fasteners based on size, thread, and type. I used these torques for setting mine. Memory is telling me it was something like 13 ft-lbs, but I'd have to look again.
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
jon.r
Jul 11, 2015 03:34 PM
Coreyr384
Jul 10, 2015 11:13 AM
