22re brake booster, will it hold pressure?
Hi, I need to know if I put say 30 psi into the booster at the vacuum port should it hold the air? I am thinking it should but I would like other opinions. Thanks
Sorry to get picky RAD, but the booster doesn't produce vacuum, the engine does, the booster uses the vacuum to help you press on the brakes. I am sure you know that but just to keep from confusing some of the newbies...
PC, why in the world would you want to pressurize a vacuum booster? Since it is designed to hold the atmosphere out (a vacuum inside) it is not designed to withstand 30 pounds per square inch trying to get out. picture how many square inches we are talking about and realize that that is a whole lot of force. Don't do it!
otis80
Mar 31, 2025 02:27 PM
WTB[PacNorWest]: 84 4Runner brake booster/brake master cylinder
user 82300
Sep 17, 2015 10:41 AM
okidoc
Aug 20, 2004 01:38 PM
