22r woes
Old Nov 10, 2008 | 09:03 AM
run4her's Avatar
22r woes
I was coming up a grade the other day when my truck lost power. It still runs but the second cylinder from the front has 0 compression all others are 120 - 125. It has spark and everything but no compression. I think it may have a stuck exaust valve. What are my options?
Old Nov 10, 2008 | 09:08 AM
22mr2's Avatar
NOt really too many. Youll have to pull the head
Old Nov 10, 2008 | 09:09 AM
run4her's Avatar
Ok i should probably just do all new valve seals and everything huh.
Old Nov 10, 2008 | 09:21 AM
22mr2's Avatar
If the valve is stuck open, you would have to figure out why 1st. Is your oil pressure good? Has it been run really low on oil or old oil? Either way it sounds like your going to at least need a new valve and guide if it is stuck. If ones bad the others probably arent too far behind.
Old Nov 10, 2008 | 09:31 AM
run4her's Avatar
ya it burns oil. It dosent smoke though so i dont know what the dealis. It was very low on oil.
Old Nov 10, 2008 | 11:34 AM
22mr2's Avatar
If you pop off the valve cover, you could turn it over by hand and see if one of the valves isnt moving, that would be a dead giveaway on what your up against.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
