22R Oil Pump Removal...
Old Aug 8, 2008 | 09:01 AM
84YotaBigRig's Avatar
Question 22R Oil Pump Removal...
I need a little help with getting my oil pump off to replace the seals. I've got the first pully off, now I need to get the balancer off. Any tricks on how to get this darn thing off?
Old Aug 8, 2008 | 09:03 AM
waskillywabbit's Avatar
Find a FSM or try AUTOZONE's online manuals in the "repair info" on their website.
Old Aug 8, 2008 | 09:08 AM
Autozones tells me to remove the oil pan, strainer ect but the oil pump is mounted to the front of the engine, why would I need to remove all that stuff?
Old Aug 8, 2008 | 09:47 AM
I dont have a breaker bar so whats the next easiest way to get this !@#$ balancer off!?!
Old Aug 8, 2008 | 10:23 AM
wrnchplr's Avatar
If your only removing the pump there is no need to remove the pan and other stuff....
you could go to checker and in there loan a tool they have a puller that works just for these.....
or us a big screw driver and gently push on the pulley from behind. go from side to side, also try some spray lube to loosen things up.
Old Aug 8, 2008 | 11:43 AM
thanks...I went and got a breaker bar from my buddy's shop and did the crank the engine method. worked good!
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
cars-guy
Jul 11, 2015 07:51 PM
87blyota
Jul 10, 2015 04:31 AM
