22R Engine Pics
Old Jan 5, 2006 | 05:10 PM
84pickup's Avatar
22R Engine Pics
Does anyone have any good pics of their engine compartment? I have some electrical gremlins I'm trying to trace. A bunch of guages don't work, and I've got some wires with ends hanging loose (passenger side, battery/fuse box area). I need to figure out where they should connect, and trial and error is not working.
Any help would be appreciated.
Thanks
Old Jan 10, 2006 | 06:32 AM
fourwd1's Avatar
Why not post some pics of the wires you are trying to identify, it would make things easier.
Old Jan 10, 2006 | 05:48 PM
84pickup's Avatar
Sheet, Thats a good idea. Tomorrow. Thanks.
Old Jan 10, 2006 | 06:14 PM
tc's Avatar
tc
22R is pretty *$&#$ simple - can't be too hard to diagnose!
What kind of electrical gremlins?
Old Jan 10, 2006 | 09:20 PM
Flamedx4's Avatar
Does this help?
Old Jan 10, 2006 | 09:28 PM
EWAYota's Avatar
Originally Posted by Flamedx4
Does this help?
I love chocolate dipped yota's with a dash of 22R in it!
Old Jan 11, 2006 | 04:16 AM
84pickup's Avatar
Haha, yeah, now I know where my left headlight goes!
I'll get a pic up soon.
Old Jan 11, 2006 | 08:01 AM
maxpower_hd's Avatar
Pictures
There are not a whole lot of electrical things to look at in there but here a three pictures of a 1984 engine compartment. I'm moving this out of the garage in a few days so let me know if you want a close up of anything.
engine bay 1
engine bay 2
engine bay 3
Old Jan 11, 2006 | 03:08 PM
84pickup's Avatar
Thanks a lot man, that helps.
It looks like I have a hose missing too, from that little thing right behind the fuse box, and I have a spot where it should hook on the carb (I assume at least, since there's a spot right across from it).
I've got more wires in that same area, I'll have to get some pics up so you guys can have a look. Tomorrow in the light.
Thanks again.
Old Jan 12, 2006 | 04:06 AM
No problem. Let me know if you need any other pictures in the next week or so. The truck is going back outside so I can do a motor swap in a 93. I get home when it's dark so I won't be able to get any good pics after it's out.
Old Jan 12, 2006 | 05:14 AM
84pickup's Avatar
First time with photobucket, so hope this works.
Mine's not as clean and dry as yours, but hopefully you guys can figure some of this out.
http://i47.photobucket.com/albums/f1...j/overview.jpg
In the overview shot, you can see a few problems.
1. The hose coming from under the breather, where should it end?
2. The red wire that comes out of the firewall is coiled up and not connected to anything. What is it, and where should it go?
3. Right behind the fuse box, there's a little copper nipple that I assume should have a hose connecting to a spot on the carb, which you can see in the next pic, right above those 2 bolts?
4. And the hose with the pinch clip on it, thats sticking out pretty straight, what is it and where should it lead?
http://i47.photobucket.com/albums/f1...j/carbhose.jpg
http://i47.photobucket.com/albums/f1...enFittings.jpg
And my green fittings are just floating around ( I know, probably not good). I don't have one connected where I saw one on yours, nor do I think any of mine would even go there, based on wire lengths and where they are now.
http://i47.photobucket.com/albums/f1...j/Oilguage.jpg
And finally, (for now), the wire that had a boot on it I presumed was for the oil guage, but isn't working. It used to, but has stopped. Maybe just a bad connection. Is it the right wire?
And I assume the temp guage is the one up top near the front, and it's not working either.
So these are the gremlins I'm tracking down, some electrical, and some are those hoses. Keep in mind, the truck works great, just the oil and temp guage don't. Maybe it will work greater if I can connect some of this other stuff. Any help would be appreciated.
Thanks again.
Old Jan 12, 2006 | 05:35 AM
fourwd1's Avatar
Originally Posted by 84pickup
And finally, (for now), the wire that had a boot on it I presumed was for the oil guage, but isn't working. It used to, but has stopped. Maybe just a bad connection. Is it the right wire?.
Yes. Tha's the sender for oil press. Could be a bad connection or sender could be bad (or gauge itself).
I'll try to compare to my 84 tonite.
Old Jan 14, 2006 | 03:58 PM
84pickup's Avatar
Can anyone offer anything else?
Old Feb 18, 2006 | 05:54 AM
fustercluck's Avatar
where are you, 84? I can't post pics on here from my digi cam (can't figure out how to resize the images small enough to make the server happy) or I'd take detailed pics of my 84 for you. I had the same problem in another truck I rebuilt. The motor came to me in the bed of the truck and I had to figure it out Inspector Clueseau style
Perhaps I could email you some pics.......
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
jon.r
Jul 11, 2015 03:34 PM
87blyota
Jul 10, 2015 04:31 AM
