22r carb misfire
22r carb misfire
I just rebuilt my 22r aisin carburetor. I’m noticing it has quite a rough idle and stumble at idle when warm and off the choke cam. Can’t seem to figure out what it is. I’ve adjusted the mixture to the factory 3 1/2 turns out, messed around with it and don’t notice any change unless I turned it way out. So I left it as factory.
It’s desmogged, just running vacuum for the AAP, choke break, choke opener, HAI, and distributor ports.
I’m also noticing there’s not much give low on the throttle, almost feels like it’s slowing down with a little throttle, need to push it pretty far to actually accelerate.
jackedmini
Apr 9, 2007 06:25 PM
