22r to 22ret
Old Feb 2, 2007 | 11:00 AM
harpen123's Avatar
22r to 22ret
has anyone swapped a 22r for a 22ret I found one fairly cheap and was wondering if it can be done.
Old Feb 2, 2007 | 11:13 AM
Elton's Avatar
sure it can be done but the wiring is the fun part
Old Feb 2, 2007 | 11:22 AM
harpen123's Avatar
I made a comment about doing this and someone said something about an inline fuel pump like an auxilary one.
Old Feb 2, 2007 | 11:34 AM
dcg9381's Avatar
Check the engine and turbo out well.. They're expensive to repair if they don't work right.
harpen is right, you'll need a high pressure EFI pump. You can use an inline pump if you want.
Wiring the ECU is the "hard" part. Ping me if you have questions... I've got most of the diagrams for the 22rte ecu if needed.
You could also wire it into a stand alone, but the stand alones I use are about $500, so it might blow your budget...
Old Feb 2, 2007 | 11:43 AM
harpen123's Avatar
the engine has already been pulled what should I inspect besides exterior appearance and such.
Old Feb 5, 2007 | 08:19 PM
dcg9381's Avatar
Play in the turbine, side to side vs in/out. There are specs in the FSM.
Do a leak down test.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
