1985 toyota sr5 pickup, 22re engine will not turn over when cold out
Old Jan 4, 2014 | 08:21 AM
WRI's Avatar
WRI
My 1985 toyota sr5, 22re engine will not crank/turn over when it is cold temps outside (usually below 32 degrees F). It only makes a slight buzzing noise coming from the location where the ECU is at when you turn the key to start. In warmer temps outside the truck cranks right away with no issues. Battery CCA is 930. It was tested and was fine. This problem has been going on with other batteries installed as well. Anyone else have this issue?
Old Jan 4, 2014 | 08:24 AM
BigBluePile's Avatar
Lol, I almost posted on your other post to post on another site that bas more posts about posts like this post.
Old Jan 4, 2014 | 10:23 AM
WRI's Avatar
WRI
After further troubleshooting from switch thru harness to starter it seems to be in the solenoid.
Old Jan 4, 2014 | 05:32 PM
WRI's Avatar
WRI
Turned out to be worn contacts.
Old Jan 4, 2014 | 10:15 PM
Well, easy fix!
6th Gear
19
Dec 10, 2019 07:31 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Eagle564
Jun 23, 2015 11:29 PM
infinityisfive
Jun 16, 2015 06:51 PM
JaredL
Jun 16, 2015 04:47 PM
