1985 GREEN 4runner
Old Sep 9, 2019 | 07:12 PM
nadakai's Avatar
1985 GREEN 4runner
Hey guys, been a minute since ive posted on here. Figured I had better start a thread for thing like I did for my last 2. Purchased in september of 2017, 173k on it at the time. This is my daily driver and only vehicle at the moment. I will try and backlog all stuff I have done over the last couple years
Old Sep 9, 2019 | 07:25 PM
Discombobulated's Avatar
I like it, more pics please
Old Sep 9, 2019 | 08:08 PM
nadakai's Avatar
first thing I did was replace these with OEM tails
Old Sep 9, 2019 | 08:19 PM
nadakai's Avatar
Up next was of course the mandatory american flag decals
Old Sep 9, 2019 | 08:31 PM
nadakai's Avatar
Around this time it started to leak oil from the front main seal, so i replaced the oil pump, water pump, sleeved the crank for new front main seal, resealed the oil pan, and replaced a still functional alternator
Old Sep 9, 2019 | 09:03 PM
nadakai's Avatar
New ignition cables
New rad cap fron 22reperformance
Old Sep 9, 2019 | 09:04 PM
nadakai's Avatar
Picked this up for 300$, havnt made much progress on it yet
Old Sep 9, 2019 | 09:59 PM
nadakai's Avatar
Took it camping
Replaced old worn out shocks with bilsteins
Old Sep 9, 2019 | 10:08 PM
nadakai's Avatar
Had the priviledge of using my buddys lift to replace the wheel bearings, its always easier with the right tools!
Changed up the front end a bit..
Picked up a rare sr5 cluster.. more on this later
New torque arm bushing and half of a u bolt flip kit installed
Old Sep 9, 2019 | 11:27 PM
nadakai's Avatar
AC tensioner pully decided it wanted to run away, replaced it and was thankful to have ac again
Old Sep 10, 2019 | 01:17 AM
nadakai's Avatar
Could a mod please move this to the build up section? Realized I posted it in the wrong spot!
Old Sep 10, 2019 | 05:12 AM
Fricken excellent!!!
whats the plan on the turbo motor?
Old Sep 10, 2019 | 07:13 AM
jakey poo's Avatar
Love the color!
Old Sep 10, 2019 | 03:46 PM
nadakai's Avatar
Strip it all down, and have the machine shop do its thing. Then I would like to do the rebuild myself. May look at upgrading some components of the head while I am at it. Im thinking ill keep the boost around 7-10psi. Need to decide on an exhaust manifold and turbo and whether or not to intercool it, and a mega squirt system
Old Sep 10, 2019 | 04:10 PM
Sweet, I was wanting to do the convert years ago but never pulled the trigger, came across this page:
https://people.well.com/user/mosk/
A bit dated but good info
sweet man, ride is killer!!! Can’t wait to see some turbo!!
Old Sep 10, 2019 | 04:15 PM
nadakai's Avatar
Thanks for that info! Some good stuff in there for sure. I have a feeling the turbo will be on the backburner for a little bit. Right now the 4runner is down. I broke it when I was starting the gauge swap and a bit ashamed of myself for it. I will post some pics and let you guys try and figure it out!
Old Sep 10, 2019 | 04:17 PM
nadakai's Avatar
Old Sep 10, 2019 | 04:31 PM
millball's Avatar
Shouldn't be too hard to ezi-out that butt.
Old Sep 10, 2019 | 04:32 PM
nadakai's Avatar
Yes, that's what I was thinking. BUTT the problem is its location. It is close enough to the frame I cannot fit a drill there, and had no luck with a 90 degree adapter either.
Old Sep 10, 2019 | 04:38 PM
millball's Avatar
Shouldn't need to drill it. Just gotta have the exactly correct ezi-out.
I like the Proto square type extractor for work like this. I've even used the tang of an old file, ground just right.
