1985 4x4 ext cab
Old Apr 9, 2017 | 07:33 PM
flg8r22's Avatar
But you dodged the computer bullet. 85 started efi and vacuum line monster. Seeing another carb truck on the road is awesome
Old Apr 9, 2017 | 07:37 PM
rtrippva's Avatar
Originally Posted by atcfixer
85 also has the solid front axle too. Model year 86 is when it went IFS (around Sept 1985).
True I've built a 2013 Tacoma and wanted to go Ole School.....lol
Old Apr 9, 2017 | 07:44 PM
flg8r22's Avatar
Nice rig! Is than an old Cadillac in the back?
Old Apr 9, 2017 | 07:49 PM
rtrippva's Avatar
I belive so. This was at my buddy's stereo store.Howes Audio.
Old Apr 10, 2017 | 02:46 PM
  #25
Nervo19's Avatar
I'm starting to love red trucks. I forgot until just now I've already owned two red trucks and a red VW, MG and Corolla. I guess I DO like red. That cleaned up nicely. It would be nice to have a truck with no ECU. Are you somewhere in VA due to your screen name?
Old Apr 14, 2017 | 04:10 AM
  #26
I8URSVT's Avatar
Should be a great starting point. Glad to see another x-cab being saved!
Old Apr 16, 2017 | 05:38 PM
  #27
rtrippva's Avatar
Yep Chesterfield
Old Apr 16, 2017 | 05:39 PM
  #28
rtrippva's Avatar
Thanks. It's going to be fun for sure!
Old Apr 16, 2017 | 06:19 PM
  #29
Nervo19's Avatar
Originally Posted by rtrippva
Yep Chesterfield
Hanover. That dash is pretty cracked for VA. That's far down he list but I think you can fiberglass it.
I look on Chesterfield Auto Parts once in a while and they never seem to have old Toyotas . They have an all truck yard in Midlothian. They list the vehicles on their web site. I'm not sure of anywhere that has Toyota truck parts in the area.
Your 2013 is beautiful.
Old May 8, 2017 | 04:35 PM
  #30
rtrippva's Avatar
Thanks. It's been fun fixing up the 2013 but now it's time for a real challenge....the 1984 pickup.
Old May 8, 2017 | 04:46 PM
  #31
rtrippva's Avatar
Frame is F@€¿%d
Alright fellas, I've had some time to mess with this truck and the frame probably has 400+lbs of plate steel welded from front to back!!! Along with a few spots still in need of more. So I did some searching and found a 1984 extra cab frame with supposedly just surface rust. I have to go look at it but he wants $200 for it. So here is the question, is it worth trying to swap EVERYTHING over to a new frame? I'm a HVAC mechanic by trade not a auto guy. So how realistic is it for me to attempt this task?
Old May 8, 2017 | 05:49 PM
  #32
atcfixer's Avatar
5 Year Member
Frame swaps are not exactly complicated, but TIME is normally the biggest issue. For a pickup, you basically unbolt the 8 bolts for the bed, unplug the tail light wiring and get it free from the box holders, and the license plate lights and lift it off with a friend. The cab is 6 bolts, the tail light/tank wiring unplugs under the passenger seat and stays with the frame. The rest of the front end harness you'd have to work with. The engine sub harness should unplug from the body harness around the passenger side area. Parking brake, wiring, and brake lines, and the cab should be free to lift up. Either you'd have to lift the cab very high to clear the engine, or remove the engine/trans with the cab still on the frame. a couple 4x4s, plenty of blocking, and a high lift jack works fairly well. Pretty much it's just repeat what you did in reverse to put it back together. Exhaust might be your biggest problem, but you could have an exhaust shop make you up an exhaust, or see if you can drop your exhaust off the frame as one full length if it's in good shape yet. Overall it's defo a lot of work, but not all that complex except the wiring/brakes etc in the front area.
$200 for a solid axle frame (4x4 right?) is quite cheap unless it's the bare frame no axles. If you do go after the frame, bring a small hammer or something to tap the frame with, and check the bottom and inside areas of the two main frame rails. Generally they rust from the inside out due to the boxed in design, so the outside can look great, and still be about really to rust though.
Old Jun 5, 2017 | 08:24 PM
  #33
HiLuxer's Avatar
Subscribed to this thread. I also have an 85 extracab with 5 speed and EFI that I'm gradually working on. You've got a steal there even it seems like it has a bad frame to begin with.
Old Jun 15, 2017 | 07:00 PM
  #34
rtrippva's Avatar
Well got the truck running. New battery and fuel pump,drained gas tank and oil change and fluid check. Runs OK for now. Put some new tires and now digging into the brakes. Did notice real wheel is jerking a little on take off on gravel. So will be looking into transfer case and drive shaft.
Old Jun 19, 2017 | 06:27 AM
  #35
rtrippva's Avatar
Question fellas, does the 1984 pickup come with the corner vent windows? or was that a later year?
Old Jun 20, 2017 | 01:13 PM
  #36
bootscootboogie's Avatar
Any doors from 1984-1988 are interchangeable. Extra cab. 4runner. 2WD. 4WD. Doesn't matter.
Old Jun 21, 2017 | 06:17 AM
  #37
HiLuxer's Avatar
I'm pretty sure it does. My 84 4Runner has vent windows but my 85 pickup doesn't. I think it's a factory option at the time of purchase.
Old Jun 21, 2017 | 10:06 AM
  #38
L5wolvesf's Avatar
I have a base model 84 pickup - no vent window.
Old Jun 23, 2017 | 06:38 PM
  #39
rtrippva's Avatar
Gave the truck a serious purple power power washing today but ran into a few problems. I guess the alternator took a ˟˟˟˟ cause now I've got a batt light and a brake light on in the dash. Also I cleaned the ˟˟˟˟ out of the undercarriage and my parking break is now stuck engaged. The worst thing is I blew my 22R sticker off the motor😢!!!! All I was originally going to do was change my belts.....smh😕
Old Jun 26, 2017 | 07:57 PM
  #40
maco35's Avatar
The 22r stickers aren't expensive....http://www.lowrangeoffroad.com/toyot...er-decals.html
