1985 22re Motorhome where to put jack?
Old Apr 9, 2013 | 02:41 AM
pcmentor's Avatar
Is it safe to use a bottle jack on the rear pumpkin with free floating axle? What about using a floor jack? I have visions of the bottle jack punching a hole in the bottom of the pumpkin. 6 ton Bottle jack and 3.5 ton floor jack. Thanks
Old Apr 9, 2013 | 03:06 AM
pcmentor's Avatar
From FSM, should I be concerned about the extra weight of motorhome though?.Name:  liftpoints.jpg
Old Apr 9, 2013 | 07:10 AM
YoungFeller's Avatar
A floor jack under the differential pumpkin is acceptable, assuming the ground is flat and you don't lift it up too high.
I wouldn't use a bottle jack under the pumpkin, mainly due to stability/safety reasons. I would only use a bottle jack to lift one end of the axle and use the spring U-bolt plate as a lift point. Lifting an entire axle with one or even two bottle jacks is just asking for trouble, imo. There's a large probability of the jacks toppling.
sandyota
Feb 4, 2021 11:16 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
bryan34w
Jul 6, 2015 05:53 PM
