1985 22RE missing terribly - out of nowhere
Old Feb 14, 2014 | 12:55 PM
thisismyusername's Avatar
Originally Posted by CamTom12
Almost success!! Due to the weather in the Northeast, my new CLT isn't here yet (not sure why it shipped from CA to MA to NH to get to AL, but whatever!). BUUUUT, I went down to radioshack and picked up a potentiometer and a 0.47 ohm resistor. I used the pot to set about 2 ohms (I couldn't find a resistor that size) to let the truck warm up and after it did I put the 0.47 ohm resistor on there with some e-tape to keep it safe. Those resistances come out to about 60*F and about 170*F respectively. When it's getting proper resistance according to temp, that thing runs awesome! I'm going to drive around a bit this afternoon, and I've still got the pot to use for warm-up if my CLT doesn't make it in tomorrow. It's kind of a pain, but it makes me happy to see it running. Good thing I don't need to commute in it, hahaha.
well that's great then! Yeah I would feel good too Haha. Well, good luck!
Old Feb 14, 2014 | 05:08 PM
CamTom12's Avatar
Just ordered this:
http://www.rockauto.com/catalog/more...343&cc=1272136
Terry, you ought to order one too!
Old Feb 16, 2014 | 11:25 PM
Terrys87's Avatar
THANKS!!!! I have tried finding these online with no success. I appreciate you posting these up for me. I need to get 8 of these on order as I have two harnesses that the connectors were tore up on me when I got them. Thanks again.
Old Feb 17, 2014 | 07:55 AM
CamTom12's Avatar
No worries!
Old Feb 19, 2014 | 02:57 PM
  #25
CamTom12's Avatar
Almost success!!
The new CLT came in the mail and I got it installed earlier. I can now confirm 100% that this was the problem. The old one actually fell apart as I was removing it. I still have the old plug on it, just kind of pushed on there but it hasn't moved yet. New one should be here in the next day or so and then I'll get that spliced in.
Old Mar 1, 2014 | 04:14 PM
  #26
CamTom12's Avatar
Bad news everyone!
There's a slot in the side of the connector that's centered. It needs to be off center. The connector I linked won't work.
Back to searching the internet.
Good news is that I made a new makeshift metal clip using a paperclip so the old broken connector will stay put on the new sensor until I can find the right new connector.
Old Mar 1, 2014 | 10:31 PM
  #27
Terrys87's Avatar
At least you know what the problem is and is just a matter of finding the correct part. Worse case scenario is to get another out of the boneyard. Probably not much better then what you have, but I have done it in the past.
Old Mar 2, 2014 | 06:01 AM
  #28
CamTom12's Avatar
Yeah. I sent an email to rock auto, so hopefully they'll come back at me with a different part #. I hope I caught this before anyone else ordered any!
Old Mar 2, 2014 | 10:42 AM
  #29
CamTom12's Avatar
Rock auto replied to my email. They don't have and can't special order the right one. I'm going to shoot the manufacturer a picture of what I bought vs what I need and if they can't come up with the right part I've decided to just dremel the index off of the sensor itself. Then the connector will fit snug and secure.
Old Mar 3, 2014 | 01:47 PM
  #30
Erik Hinch's Avatar
CamTom what was the part number on the CLT? I can't seem to find one. I changed the Coolant temperature sensor, did not fix he lack of idling up issue.
Old Mar 3, 2014 | 02:07 PM
  #31
CamTom12's Avatar
I'm not sure, I just called 22RE Performance and they shipped me one. Way cheaper than the dealership.
If you're not idling up I'd start looking more along the lines of your aux air valve. Idle speed is more controlled by air than by anything else.
Old Jan 12, 2016 | 08:56 PM
  #32
1985 4Runner's Avatar
Subscribed to this thread. Am starting a top to bottom inspection of my newly acquired 1985 4runner and some troubleshooting as well, I have an intermittent idle/miss issue. You seem a lot more knowledgeable on the mechanics/electronics than I am
Looking forward to your progress.
Old Jan 13, 2016 | 05:41 AM
  #33
CamTom12's Avatar
When's the last time you changed plugs and wires? I cleaned up a slight idle stumble with new wires a while back. I wasn't sure on the ignition history so I just swapped everything to new parts (dist cap, rotor, wires, coil, plugs).
Old Mar 2, 2016 | 06:51 AM
  #34
I haven't changed the plugs or wires. Truck is new to me. What is CLT?
Old Mar 2, 2016 | 10:01 AM
  #35
CamTom12's Avatar
CLT is a coolant temp sender that I believe the ecu uses to set different fueling tables and maybe timing tables based on engine temp. That's just my guess.
Good news is that my truck has drastically reduced the "rough running after cranking" events. They're limited to a specific temperature on warm start now. But it happens rarely enough to this point that I haven't gotten around to further troubleshooting. If it happens I manually throttle up and hold the engine to ~1500 rpm until it quits. Usually that's about 10-15 seconds. When it happens and I just let it idle on its own it's a pretty violent event. If you have a slight stumble if look at plugs/wires first.
Old Mar 3, 2016 | 07:09 PM
  #36
Cleaned my throttle body yesterday & got a ton of gunk out. Truck runs like a top now & idles at 1000RPM, no issues.
Old Mar 3, 2016 | 10:09 PM
  #37
CamTom12's Avatar
Good deal!
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
adammtb
Jul 27, 2015 11:57 AM
bryan34w
Jul 6, 2015 05:53 PM
