1984 4Runner Transmission Swap
Old Aug 2, 2018 | 11:17 AM
Dano AL's Avatar
I know I will get heat for this but, I want to put an automatic trans in my 84 4Runner so its easier for my wife to drive our kids in. They love it and she would like to drive it also. It has a 22r motor and I was wondering if a mid 80's celica/corolla trans would bolt up. Thanks for the help, and I know...I know.
Old Aug 8, 2018 | 07:40 AM
SENOR NOODLES's Avatar
Swapping in an auto is sometimes pretty involved I would find an AW4 from a jeep, get the adapter to a toy t-case, and get the bellhousing and torque converter/flex plate/spacer, from a a340 from a 84 and up Toyota 22r-re automatic truck.. Then you will also need the throttle pressure cable from the trans to carb. assuming your 84 runner has the original 22r. A a340 is a direct swap, but you will want to keep the Toyota t-case, or swap in a d300, so the AW4 is needed.
Old Aug 8, 2018 | 08:03 AM
I believe you will need the harness and tcm as well from an auto toyota
Old Aug 24, 2018 | 08:35 AM
Dano AL's Avatar
Thanks for the info. So an A340 is a direct swap if found. I would like to keep mostly toyota parts if its possible.
Lewiston49
Mar 23, 2014 05:43 PM
Andrew James
Dec 9, 2013 07:15 PM
SLC97SR5
Apr 13, 2008 08:28 PM
jeffs84runner
Mar 13, 2007 07:55 AM
