1984 22R smoking
Old Oct 2, 2010 | 08:29 AM
Uthro69's Avatar
1984 22R smoking
My 84 22r has been spitting out white/grey/blue smoke cant tell very easily, But its not coolant ive been watching it carefully if its burning anything its excess fuel or oil.. After its been sitting for a while it will start really roughly and vibrate. I feather the gas pedal and it wants to almost stall but then it smooths out after she warms up.
On the valve cover i replaced the pvc valve, and the hose that is supposed to bring fresh air into the crank case from the air cleaner is actually having blow-by its not pulling in fresh air but its blowing out an oil mist causing buildup ontop of my valve cover.
I think that the valve stem seals are toast or more fearfully the guy i bought it from got gas into the crank case and ran it like that and toasted my rings causing blow back pressure.. Im looking for ideas and opinions ive looked around on the forums. Im running syn-blend castrol gtx 10-40 i live in satans basement and thought about changing it and putting in 20w50 just to give it better hold up in the heat..
Go Go Yotatech ---
Old Oct 4, 2010 | 05:46 PM
myyota's Avatar
If your getting a lot of blow by out of the valve cover then it sounds like the rings arn`t sealing. Sounds like its time for a rebuild. It would be a good idea to do a compression check on all the cylinders to see were your at.
Old Oct 4, 2010 | 05:47 PM
HighLux's Avatar
agree with above
Old Oct 4, 2010 | 06:35 PM
Uthro69's Avatar
thats not what you guys are supposed to say 65k miles and i gotta rebuilt ASdasfnkldshfds
Old Oct 9, 2010 | 12:01 PM
usmc-lazer's Avatar
It sound to me like the rings didnt set right and wear in they way there supose to.
Old Oct 10, 2010 | 09:29 AM
check6's Avatar
I concur with others. Sounds like rings and/or valve guides are ka-put. Why would someone run gas in crankcase???? Do a dry, then wet,compression test. Follow up with a vacuum meter test just to confirm.
Old Oct 25, 2010 | 02:22 PM
fourplayoffroad's Avatar
What do you guys think of delo 15w40 in a 22re for oregon weather? I always usw wix filters but i may switch to toyota
Big Little Bear
230
Nov 13, 2023 11:42 AM
Corvoid
Dec 11, 2015 11:21 AM
Bowman5115
Sep 29, 2015 08:55 PM
user 82300
Sep 22, 2015 07:00 AM
Bowman5115
Sep 19, 2015 03:04 PM
