1984 22r egr/vacuum line delete
Old Oct 18, 2015 | 04:03 PM
buckz6319's Avatar
Originally Posted by kawazx636
only need 2 vacuum lines - one from the distributor (Normal/ported advance - the port closest to the radiator) to the carb and one from the distributor (Idle/Manifold advance - the port closest to the head) to the manifold. And you'll have a larger vacuum hose going to your manifold if you want to run the brake booster (recommended). Cap EVERYTHING else.
should look like mine:
I have been searching for hours on how to hook up the fuel hard lines under the intake of my 87 22r carbureted.
I see that you have labeled yours "I" and "R" Great!!!! now I have an idea which is "fuel in" and "fuel return". I didn't have the luxury of labeling and removing mine, so now that I know which hard line is which, thanks to your pic!. I would like to know if you have a pic of the fuel tank hard lines just below where those are that you labeled, so I can hook mine up correctly
I would greatly appreciate it if you can help me out
thanks!!
Old Oct 20, 2015 | 11:22 AM
kawazx636's Avatar
thanks!!
Nope, can't help you out there - I bent all new hard lines back to the tank so mine look nothing like stock.
Old Nov 23, 2015 | 05:00 PM
Rand1y's Avatar
So what about all of the vacuum switches and choke opener on the carb? Block it off? My 22r is running good but it won't idle!! Missing the charcoal canister but I don't think that is needed?
Iceman4193
Aug 28, 2015 08:43 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
e_richard
Jul 30, 2015 06:50 PM
BK2TFUTURE
Jul 28, 2015 10:01 AM
Dakotaneu
Jul 27, 2015 12:03 AM
