Your Trucks Top Speed
#61
I took it to around 90-100mph with my 32 ( measured 30.8") tires, it had more in it too. Not willing to try it with my new ones. Plus I don't need a ticket. Fastest I really need to go is around 60-65mph
#62
I know it's hard to believe, and I don't understand this pehnomena either but here it goes. I used to have a 1980 Toyota Pickup with a 22r, stock 4 speed in it, 4.36 factory gears, and 36x12.5" Swampers. It used to accelerate quick, cruise the highway at 70mph but if I wanted to I could push it up to 80 in 3rd gear.
Now I have a 1989 4runner with a 22re, 33x12.5" swampers, welded rear end, and this thing is a total slug compared to the Pickup. I mean seriously, all it can do is 65. Probably a worn out motor though.
#64
From: Yotatech, because Pirate is too expensive. NorCal.
How do you know you went 90? I have exectly the same truck just long bed and the speedo only goes to 80. I have pinned it a couple times though and it gets there fast enough. Its kind of a sleeper. You know people look at it and think crappy old two color truck and then they get mad when I can take them. It will smoke the first two gears and third if its wet out, geat fun to drift also...
#65
When I have a tail wind of 50 miles an hour downhill and the planets are aligned right, I can hit around 85! Not quite fast enough for time travel, so that flux capacitor I got awhile back is useless....
#67
Ok, the fastest I've ever gone in my 94 4Runner was 95MPH. I was scared to go too much faster, even though it was a flat straight rural road with no other cars. I just can't imagine how stupid I'd feel if I got pulled over, and probably arrested for going over 100MPH.
I have been tempted to hit the 100MPH mark since then. My 4Runner accelerates pretty good from 65-80, but after 85, it takes forever to go faster.
BTW, I have 4.10's, and 31's and 3.o-yeah.
I try to keep my high speed ventures somewhat limited to sports cars, and the occaisional rental...
#70
Honestly i think the hardest ive pushed the 3.0 is 95, i might have to nail 100 one day just to say i did! Its not a big deal really!
But when im at 95 at 4 something thousand rpms, my only thought is (besides getting pulled over or hitting someone) Now how long before the head gasket is toast?
So then i slow it down
#72
I had an 86 pickup that i got up to 110 miles per hour on flat ground with 35's on it. I think it was the gears that mad it go that fast. It had 5:71 gears. I would never buy that tall of gears it came with them.
#74
#76
My 81 4x4 with 33s gets bout 60, even with the rebuilt motor. Im gonna regear it tho. The 2000 Tundra 2wheel drive, so far I stopped at 112, switching lanes in all terrrains got kinda squirrley so i slowed down, plus i dont need another ticket.
#79
1977 20R 4spd 2wd 4.10r&p 195/75R14
85mph - gear limited. I could probably squeeze a few more mph out, but without a tach I'm pretty sure I'm near/past redline at 85. Fastest comfortable cruise speed is about 75mph. I don't really need to go any faster, but a 5 speed sure would be nice to keep the RPM's down.
#80
in a knocking 22r, carb problems, no exhaust, no manifold, no oil, no antifreeze, in 4 low hubs unlocked, i managed to get 2 gear floored about 2000 rpm, wouldent go any faster, that was in my 82 on flat ground....
it cuts off fuel or spark....
