Pre 84 Trucks 1st gen pickups
wideband O sensor install in original bung on 1983 22R carbureted
Old Mar 5, 2025 | 11:58 AM
travelinjohn's Avatar
I want to install an Air to Fuel ratio gauge in my 1983 toyota PU 22R carbureted(weber) engine. Can I use the original O sensor bung or does it require a new bung ? Does the oem bung fit ? Will everything work if I replace the oem sensor with a wideband O sensor ? The kit has it's own controller that only provides a reading, for tuning. What do I need to know ?
Old Mar 5, 2025 | 12:19 PM
Bingle's Avatar
I believe most of the wideband sensors are the screw in type, and the stock toyota is a 2 bolt flange setup, so I don't believe it would work.
Below is what I got with the sniper EFI setup I'm running, if welding in a bung seems like a hassle. Drill the hole, clamp on, screw in O2 sensor.
I believe you want to be at least a foot downstream of the header collector (all the pipes come together)
Hooker BlackHeart 71014303-RHKR Hooker BlackHeart Oxygen Sensor O2 Bung 2.25" Clamp-On Style
Marilyn
Apr 26, 2019 05:31 PM
Challenger
Sep 13, 2015 01:34 PM
akarchin
Feb 13, 2007 09:00 AM
prang11
Sep 25, 2005 07:22 PM
lrsu
9
Feb 18, 2004 11:27 AM
