Pre 84 Trucks 1st gen pickups
Wheel Spacers
Old Dec 30, 2007 | 12:38 PM
kkkd's Avatar
Wheel Spacers
I just got new tires and some aluminum wheels for free. They barely rub on the control arm bushing on the front. I was wondering if it would hurt to just put washers that fit snug on each stud or go and buy wheel spacers?
Old Dec 30, 2007 | 01:12 PM
seafarinman's Avatar
I would get the wheel spacers. I am running them on both my trucks front solid axles and have never had a problem with them. Just make sure to use Loc-tite on the hub studs (the ones that attach the spacers to the hub, not the ones holding the wheel on) and torque them correctly with a torque wrench.
Old Dec 30, 2007 | 02:51 PM
waskillywabbit's Avatar
We have wheel spacers on the website.
Old Dec 30, 2007 | 03:26 PM
ozziesironmanoffroad's Avatar
just remember when you use wheel spacers you should always put bigger studs in
Old Dec 30, 2007 | 03:34 PM
seanz0rz's Avatar
Guest
depends on what type of spacer you use. if you use a 1/4 inch spacer, you may need to use longer studs, if you are using a 1.5 inch for example, they have their own studs that are set in between studs on the hub.
Old Dec 30, 2007 | 04:01 PM
point taken.
Old Dec 30, 2007 | 04:13 PM
Exactly.
1/4 spacer is like a washer, so you need longer studs for proper thread engagement.
Wheel spacers tigthen to the wheel hub with including small lug nuts and then the wheels tighten to the studs pressed into the spacer and you use your wheel lug nuts.
Old Dec 30, 2007 | 06:54 PM
dropzone's Avatar
Fossilized
I would recommend using the a set of spacers. Like Previously mentioned, the 1/4" spacers won't leave enough thread (personal experience)
Here are some pictures of my '81 (before and after) 1.5" spacers:
Before spacers:
After 1.5" spacers:
Now the tires are fairly even with the sliders but stick out a ways:
punks_is_4x4
Aug 21, 2015 01:35 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
