Pre 84 Trucks 1st gen pickups
Weird Tire/Wheel Wobbeling Question
Old Jan 3, 2007 | 05:03 PM
joshd's Avatar
The guy I purchased my 80 longbox from had a set of wheels (oldschool 6 spoke alloys...Eagle brand) with 31" x 10 tires on it. The problem is when you travel down the road the wheels wobble in and out. If you look at where the wheel sits against the hub, the distance is different as you travel around the inside of the wheel, meaning that something is making the wheel sit cockeyed against the hub. Is there something that needs to be ground down on either the hub or the wheel to solve this problem, or are the wheels possibly the wrong bolt pattern slightly? I havn't tried pulling the wheels off yet as I am still doing body work on the truck, but I thought I would check here first to see if anybody else ever had this problem retrofitting newer toyota wheels or other aftermarket wheels. I really like the oldschool look of the wheels and would like to purchase a set of BFG ATKO 33 x 10.5 tires for them in the near future. Thanks for your input.
Old Jan 3, 2007 | 05:13 PM
4Crawler's Avatar
Pull the wheels off and see what is going on.
Old Jan 20, 2007 | 01:43 AM
LouisianaTom's Avatar
Prepare to GRRRRRRRRRRind
anndel
Aug 28, 2015 04:56 AM
trailgoat
Aug 13, 2015 05:54 PM
Up&Down
Aug 5, 2015 06:20 AM
accuracy
Aug 4, 2015 08:05 PM
icentropy
Jul 14, 2015 10:23 AM
