Pre 84 Trucks 1st gen pickups
unique charge light issue on 82 22R
Old 06-06-2012, 05:24 PM
warmonger88's Avatar
How are you testing the functionality? I found two at the junkyard, and neither solved my issue. I hope it was just bad relays, but I would like to know for sure before tearing out the dash again.
Old 06-07-2012, 04:08 AM
Weigle's Avatar
Not sure about your model, but the 82 and 83 charge light relay isn't under the dash it's on the passenger side kick panel...no tools required, just reach up and pop it off. I'll check the FSM for detailed instructions to test it.
Old 06-07-2012, 12:54 PM
mine is high on the drivers side kick panel, and it pops out just the same.
Old 06-09-2012, 06:49 AM
eng3inelt's Avatar
Had same problem on my 82. Replaced alternator and problem went away.
Old 06-09-2012, 07:53 AM
  #25
I'm looking at the gm one wire upgrade right now. I figured it would be a decent route to go with all of the extras I already put on the truck, and I'm still thinkin of adding more. It may or may not solve my problem, but it's happening anyway.
Old 06-16-2012, 09:07 AM
  #26
So, I got my GM 1 wire done yesterday afternoon and thought I'd add a few photos of how it turned out and what it did. I also removed the harness from the old alternator to the voltage regulator.
This is it installed, and the copper ground strap to the exhaust maifold.
But it didn't fix the problem. Both light still shined brightly, even though the swap solved the charging problem completely.
So I just took into my own hands to fix the light by removing the charge lamp relay alltogether, and now my dash doesn't bother me so much!
My only problem now is how to get rid of the brake light. I had to make my own e brake setup, but the sensor is still in place on the handle, maybe revove the wire from the sensor? If that does't work, I'll remove the bulb! But the battery is holding at 14.38 volts under a load, and the truck starts when I tell it to, so all in all, it's a win.
ashersullivan88yota
01-18-2022 05:37 PM
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
cars-guy
07-11-2015 07:51 PM
87blyota
07-10-2015 04:31 AM
Quick Reply: unique charge light issue on 82 22R
