Pre 84 Trucks 1st gen pickups
truck runs fine then stalls
Old Jul 17, 2013 | 09:07 AM
Killgore Trout's Avatar
hmmm, could your timing be out of wack, those vac advance diaphragms love to go out,.....as far as vac leaks go,...when your truck is idling, does the idle go up or down if you try to choke it out by hand (cover the top of the carb only letting a little air through your fingers) i had the darnedest time finding a vac leak on mine, ended up being at the charcoal canister.
i also noticed a huge improvement after fixing a pretty bad exhaust leak, especially when dropping into the lower rpm range (like when coasting to a stop)
sorry youre havin such a rough time nailing it down, just thought id throw out some possibilities.
Old Jul 17, 2013 | 10:27 AM
catfish21's Avatar
Just redone my exhaust and no when I stArt my truck it runs perfect and drives perfect just when I'm stopping how do I test to see if my advance is bad
Old Jul 17, 2013 | 10:40 AM
the vac diaphragm on the distributor should hold vac indefinitely, you can draw a vac using a hand operated vac pump with a gauge and watch for the vac to drop, or you can suck on the end of a piece of vac line and if it feels like youre able to suck air through,...you have a pin hole, each vac port should hold vac independently (assuming you have two some only have one) so you can test one at a time without plugging the other one.
Old Jul 17, 2013 | 10:42 AM
if it is bad, i recommend getting just the vac unit, its like 60 bucks from lc, from toyota it is insanely expensive
Old Jul 27, 2013 | 06:41 PM
  #25
catfish21's Avatar
Ok well I'm still fighting this battle well when I pulled in from work today the truck didn't die but it was stumbling very bad and I heard something bubbling well my.gas tank was bubbling bad. Well I turned it off and start It right back up and like always it runs like a champ and idles fine and the gas tank wasn't bubbling so I'm really stumped and bout ready to bring to a mechanic if a fellow yota guy can't help thanks
Old Jul 28, 2013 | 02:45 PM
  #26
catfish21's Avatar
Any info ??
Old Jul 28, 2013 | 04:59 PM
  #27
gillesdetrail's Avatar
I don't know if it has been checked or said before but there is a little vent on top of the fuel tank, are you sure it is not clogged or blocked?
Old Jul 28, 2013 | 05:49 PM
  #28
catfish21's Avatar
No I havnt checked that do you think that could be the culprit and how do u go about checking that
Old Jul 29, 2013 | 04:30 PM
  #29
Well to know if it is the culprit, when the truck starts to run like crap open the fuel cap. If you hear a sucking sound and it runs better, then that's your problem. You'll have to drop the tank or remove the bed to check that, it's a little vent on top of the fuel tank.
Old Jul 29, 2013 | 05:18 PM
  #30
catfish21's Avatar
I don't really hear it sucking but I can here bubbles for sure
Old Jul 31, 2013 | 06:35 PM
  #31
catfish21's Avatar
Well I just want to say I feel stupid but I changed my fuel filter this eavning and it is back to normal again o my tank must need cleaned very bad o changed the filter the last oil change so it didn't make it very far, I can't believe it made that big a difference but it's fixed for now and thanks for all the replies so maybe the others that was following alone change your filter and maybe think about getting your tank cleaned after 32 years of living I can imagine what's in there
Yont283
Sep 23, 2022 08:06 PM
94 bikehauler
Jun 30, 2015 11:19 PM
sharrack
Jun 26, 2015 09:33 AM
slider417
Jun 22, 2015 10:18 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
