Pre 84 Trucks 1st gen pickups
Swapping a 5 speed into my 4 speed '81 4x4
Old Sep 27, 2010 | 05:43 PM
Highlex's Avatar
Cool Swapping a 5 speed into my 4 speed '81 4x4
Hey guys. I just got an 81 pickup, the 4 speed is floppy and sucks on the highway.
Its a 22r, what tranny and parts do I need to do the swap? THANKS!!
Heres some pics
The yellow decals have since been removed. PEACE
Old Sep 27, 2010 | 07:41 PM
yotaboy82's Avatar
HAHAAHAH YES you actually cought a pic of my truck in there
edit, i just realized my profile pic is your truck ha forgot i put it on there
Old Sep 27, 2010 | 08:12 PM
Highlex's Avatar
Smile
Hey guys
I also really need some new leafs, mine are ranchos but they have sagged pretty bad!!!
Anyone got something for sale?
How would these be? How much lift can I expect.
https://www.yotatech.com/forums/f11/...9-85-a-215870/
Old Sep 27, 2010 | 08:35 PM
camo31_10.50's Avatar
so uh....who's the one with the sexy legs leaning on that roll bar?
Old Sep 27, 2010 | 08:36 PM
and since it says 2.5" lift....i'm going to go with it'll give 2.5" lift.
Old Sep 27, 2010 | 08:57 PM
Highlex's Avatar
Does anyone know for sure if these would fit on my 81?
I have been searching for hours and can't find any good solid information. It sucks ARB is an Australian based company.
Does anyone know anything about these? What would they recommend for lift?
http://www.lowrangeoffroad.com/yotam...t-springs.html
My truck is geared for 35's but will be running skinny 33's for winter
Old Sep 27, 2010 | 09:00 PM
1981 yota's Avatar
if you can weld and want a cheap lift find some chevy 63in springs.
they will give you 2 or 3in of lift
Old Sep 28, 2010 | 04:31 PM
Highlex's Avatar
So does anyone know which tranny and what else I need?...
Old Sep 28, 2010 | 04:33 PM
HighLux's Avatar
You need a L50 trans and shifter
Old Sep 28, 2010 | 04:52 PM
Highlex's Avatar
Thanks and nice user name HighLux lol!
Will the L52 work (from 1983 22r 4x4) or will only the L50 work... THX
Old Sep 28, 2010 | 04:54 PM
HighLux's Avatar
You just remember who had it first!!! Pal. lol
Old Sep 28, 2010 | 05:14 PM
peow130's Avatar
Eh from what I hear, the L series transmissions were weak.
Maybe go with a G series from a later model, or find pne out of an IFS rig.
Old Sep 28, 2010 | 05:18 PM
HighLux's Avatar
I was just steering him towards what would of been in it.
Old Sep 28, 2010 | 05:46 PM
Highlex's Avatar
I would like to put a w56 in there. But what other parts would be needed?
I don't think the clutch / pressureplate / transfer case / driveshafts / slave cylinder would work or would it?
Old Sep 28, 2010 | 05:59 PM
peow130's Avatar
I think it's all the same crap.
When you get/if you get the transmission it'll have the slave cylinder on it.
As far as xfer case, they're pretty much the same up until like 89. then they're chain drive.
You can check the clutch and pressure plate pretty easily.. Just check the part# at like schucks or somethin.
I'm sure they're the same, seeing as how the 22r didn't really change much until like 85.
and the bolt patterns are still the same.
no worries, highlux, id just rather not see him swap a weak transmission into a truck thats going to get wheeled..
Okay, well it's not THAT weak, but it's prone to input bearing failure.. which sucks.
Old Sep 28, 2010 | 06:11 PM
Highlex's Avatar
Done a little research myself and it seems i will need an older model W56 a or W56b new crossmember (bud-built builds one) and the front driveshaft will need to be lengthened and the rear drive-shaft will need to be shortened.
Or I can use an 84-85 front drive shaft and 84-88 rear drive shaft as long as they are from a toyota 4x4 with the same wheel base as mine.
Cool...
NEXT QUESTION!
I found a set of trail gear 3 inch lift leafs locally, the rears are longer and require new leaf mounts to be welded... is it just as simple as that? I won't need anthing else?
And the fronts apparently are the same length and bolt up but under extreme flex situations will the front drive shaft not have long enough splines?
Is a long spline front driveshaft needed?
Old Sep 28, 2010 | 06:30 PM
dropzone's Avatar
Fossilized
no the front springs are not the same length on the trail-gear springs.
You need a new front spring mount (mounted (1/2-3/4") forward of the front crossmember) with longer shackles.
rear springs are about 9" longer...front mount goes about 6" forward of stock mount, rear mount about 2" back
Driveshaft-you will want a long spline or square driveshaft up front....
Don't have a driveshaft made until you figure out what springs/transmission combo you end up with.
W-56's are about 5" longer than L-series transmissions.
Old Sep 28, 2010 | 07:57 PM
Highlex's Avatar
Thanks for the useful post!
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
