Pre 84 Trucks 1st gen pickups
Suspension question
Old Apr 14, 2014 | 10:52 PM
83str8's Avatar
Suspension question
what up peeps, just picked up my dream toyota. wanted to ask for some advice on suspension lifts?
first of all, is this a stock lift?
my goal is to have a lift about 4 inches higher than what it is now, i would prefer to have a legit all suspension lift including leaf springs only. don't want to run lifting blocks or shackles. I also do not want to run long travel leaf springs only because I don't do hardcore 4x4 or crawling and I don't want to ruin the frame by cutting and welding spring mounts......
any and all suggestions would be taken
Old Apr 15, 2014 | 05:58 PM
toastyjosh's Avatar
The back looks kind of lifted, but that could be what a low mile yota should look like.
Look at OME springs in the front to level it out, there like 2in springs and still have a good ride. Then buy the billys 5100 shocks all the way around you will like the ride.
http://www.rocky-road.com/old-man-em...ta-pickup.html
then this
http://www.sky-manufacturing.com/cgi...y=TOY-HDTR-001
Stuff some 33s in and call it good
Old Apr 15, 2014 | 07:29 PM
kawazx636's Avatar
It's probably not stock, but I can't tell without seeing the actual springs. I second Old Man Emu suspensions. I went with OME and Bilsteins on my build. Haven't driven it yet, but I rode in my friend's truck with the same set up and I was really pleased with the combination of on road manners and offroad capability. OME springs say they provide about 2" of lift, but I think it is closer to 3. Longer shackles do help a little too -you can get 4.5-5.5" shackles for just a little more lift (factory shackles are 3.5"). I went with 5.5" trail gear greaseable shackles on my build, but I may back it down to 4.5"
Bottom line, OME is the absolute best suspension for these trucks without having to relocate hangers or do any modifications to the suspension
Old Apr 15, 2014 | 07:53 PM
83str8's Avatar
Do you have any photos of your truck with the set-up you just described?
Old Apr 15, 2014 | 08:01 PM
kawazx636's Avatar
This is all I have right now that shows the heigh. I still have the cab off doing body work.
If I recall correctly, it is about 26" from the ground to the bottom of the frame.
Old Apr 15, 2014 | 09:22 PM
83str8's Avatar
Thank you
Old Apr 24, 2014 | 06:07 PM
CAdot's Avatar
nvdesertrunner
May 11, 2020 08:18 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
coffey50
Jul 28, 2015 10:55 AM
andrewtexas123
Jul 23, 2015 11:22 AM
Vargntucson
Jul 4, 2015 12:15 PM
