Pre 84 Trucks 1st gen pickups
starting my 83 2rz swap
Old Oct 6, 2009 | 05:31 PM
  #61
blueridder2207's Avatar
ok anybody know why I have no high idle when it's cold? I suspect I wired something wrong or there's a bad sensor or I just didn't wire something during the swap.
Old May 7, 2013 | 05:58 AM
  #62
crakinbrian's Avatar
Originally Posted by blueridder2207
Here's a pic of my mounts I burned em in hot! lolAs you can see there's a little stress hole in the frame and I welded the mounts in about 3/4" from the center of the hole
I am doing this swap in my 83 pickup 2wd. Did you use the stock 2rz mounts or22r? Im pulling the entire harness out of a 96 and putting in in my 83 including gauge cluster and everything. Do you know if I will have to get a t100 oil pan even in a 2wd? I'm building a small drift toy out of it hopefully putting 200-250 to the ground I bought full motor and 5spd trans and entire wiring for $500 so figured it was worth a shot
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
Sandman
Jul 23, 2015 08:15 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
