Pre 84 Trucks 1st gen pickups
starting it for 1st time in ten years
Old Apr 5, 2008 | 08:52 AM
blueridder2207's Avatar
Thanks for the replies guys I can't tell you how much I've appreciated your help
I've finally got it running better the ignition timing was way off so now I've got it dialed in to 0 degrees but have run out of adjustment on my distributor...I know you can take the distributor out and move it a tooth but I can't seem to get it right, I tried it like 5 times last night. Each time I set the first piston at TDC and then pulled out the distributor and tried to move it one way or the other. Any body have any suggestions as to how I can get it dialed in to 5 degrees BTDC
the1998sr5
Oct 19, 2016 12:48 PM
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
saphirekosmos
Jun 22, 2015 10:26 AM
