Pre 84 Trucks 1st gen pickups
rust! doh!
Old Sep 21, 2008 | 08:08 PM
Mic09dcsm's Avatar
Damn, it seems if you live anywhere where it snows you need a welder and fabrication abilities to keep a vehicle over a decade or so.
Old Sep 21, 2008 | 09:17 PM
Rusker's Avatar
Originally Posted by lil_mule
I notice there is no body mount visible in your pic, what did you do to address that? Mine is rotted out in the same spot you replaced, and the mount to the frame is shot(but the frame is good) n I was thinking of just running a brace all the way across the floor between the fram for support....
Do you mean connecting each side of the frame?
Old Sep 22, 2008 | 02:49 AM
4banginRunner's Avatar
that pic was taken when i just got the panel in and fitted, i later put the cab on using the stock body mount location , drilled a hole and then used the bolt to draw down the metal a bit like the factory divot
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
Brodetski
Sep 30, 2015 11:50 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
