Pre 84 Trucks 1st gen pickups
Running 35's
Old Apr 12, 2008 | 06:59 AM
operose's Avatar
running 34" LTB's on a stock '83 with 4.10's right now. It is liveable but I'll be regearing ASAP
Old Apr 12, 2008 | 07:36 AM
n16ht5's Avatar
Originally Posted by AxleIke
Get the 35's.
I've seen birfs blow up with 31's. I've seen birfs take heavy abuse and be fine on 33's. Its a crap shoot. Steering is what it is. Heavy abuse and it will crap. Mild wheeling, it should be fine.
Here is the thing. If you like the look of 35's, and you go with 33's, you'll just be pissed the whole time that you went with 33's. Get what you want, modify to fit.
i agree
Old Apr 12, 2008 | 09:28 AM
Island_Yota's Avatar
So this morning I put the stock size tires back on the truck (235/75R15) roughly a 28" x 10" tire, The power doesn't feel much different I can feel it initially when I let out the clutch but after that, its almost the same. Took it up the hwy and hit 110km/h, no shakes or anything. It rides alot better too, hit some potholes and bumps and it was smooth for once, My guess is because they are radials. I also tried 4low and I wish I could have that low of gearing with the big tires without having to re-gear haha... 35's should be on it by monday.
I also am glad I took my tires off, found a blown rear wheel brake cylinder(I knew I was loosing fluid somewhere) and I can hear how bad my pinion bearing/crush sleeve are now, time to pull that apart.
Old Apr 13, 2008 | 07:56 PM
33's
Old Apr 13, 2008 | 08:39 PM
  #25
TOYOTA 1's Avatar
Originally Posted by Island_Yota
Thinking about splitting the difference and going with 34's but there isnt much to choose from, that why im thinking 35's. Im going to run Hy-steer in the near future but il probably run the stock push pull with the drop drag link for a month or two until I decide on what Hy-steer kit to go with, Do you guys think it would be safe on some mild to moderate trails? I think 35's might be pushing it with 4:10's.
What do you guys think it would cost to switch over to some 4:88's or 5:29's and would you guys reccomend 5:29's for street use?
my buddy runs 38x11x15 boggers 4:10 gears stock (power) push pull stearing and hes never broke the stearing! only everything else lol. but it usualy breaks down becouse he doesnt realy fix anything until its to late.
oh. and the 38's lol
Old Apr 13, 2008 | 11:54 PM
  #26
Sked's Avatar
You have pics of your buds truck on skinny 38's? Im trying to decide on either 34ltbs, q78's, or the skinny 38boggers
Old Apr 15, 2008 | 04:06 PM
  #27
^ Q78's are perfect for a Toyota dude, especially in B.C., TSL's out perform anything out here in the bush.
Got my Krawlers mounted today, pics? YES.
All that sucks now is stopping, the size really isn't bothering me power wise, I can still use all 5 gears on the hwy, cruises nice and low in 5th down shift for hills.. its all good, probably gets awesome hwy mileage too.
Now the real test.. off road, im taking it out soon on a really light trail, Need to do the rear brakes and swap out the 3rd Member for my spare which is in mint shape, also need to adjust my steering stops out a bit so I dont kill the birfs. Forgot to mention, the only rubbing is at absolute full lock on the spring clamps so adjusting the steering stops out a tiny bit will fix that too.
Old Apr 15, 2008 | 04:13 PM
  #28
TOYOTA 1's Avatar
here's the only good one i have, before his truck got stolen and its not that good.
Old Apr 15, 2008 | 06:52 PM
  #29
Sked's Avatar
Island your truck looks killer with that rubber. And yes, the q78's would be very dope. I ran fat tires and skinny, and by far the skinnys are better in almost all conditions except sand or really deep snow. So much more bite, its crazy
Old Apr 15, 2008 | 07:56 PM
  #30
Agreed, Q78's are like... made for Toyota's, 11.5" wide, 35.5", perfect. Im not a fan of wide tires either but I got the old 33's for cheap, and traded em for these..so I guess my truck is gonna be on wides for awhile, they arent too bad sucked down on the 8" wide wheels. My brother has the 34x9.50 TSL Narrow SS's on his LWB sami with Toy axles, they are awesome.
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
