rear lights need help guys
i got a 83 yoter flatbed. left light brake light tailight and turn signal work. right one tailight and turn signal but no brake light. hwo can i find out wich wire is what, and i re wired it all but i cant find the brake light wire i guess. i replaced the light alrdy. any ideas
I just wired in trailor lights into my 4runner and the way I figured out wich wire was what was just by putting the turn signal on and then check each wire with a circut tester or a volt meter untill you find then one that's got power. to find the brake just find something heavy enough to put on the brake pedal to get your brake lights on and go through all the wires with a tester untill you find the right one.
also maybe before you go do all that, more then likely if it's not the bulb itself it could easily just be the copper contacts where the bulb plugs in, i just had that problem with my front right corner light. sometimes water can get in there and the copper gets that green film on it and you no longer get power to the bulb.
ok guys need help big time. mom is gonna kill me if i dont finish my lights tomorrow. from the trailor light plug on the back right of my truck the previous owner wire it in and on the other end is, a white wire not being used because my light is hard ground alrdy. i know brown is power and then i got green and yellow. i have tried every conversion possible still nothing. on the other side of this connector the red wire is brake light, and i cant figure out turn signal. i got my tailights workin. ntohing else. plz help me out.
cchinny
Jun 25, 2015 08:11 PM
UKMyers
11
Jun 24, 2002 05:41 AM
