Pre 84 Trucks 1st gen pickups
Question for the masses
Old Feb 18, 2016 | 07:58 AM
Davidtank95's Avatar
hi, I've been working on my 77 toyota pickup and I've been having a issue with the timing. even when i adjust the distributor cap i can't get the timing mark on the pulley to line up with the mark on the engine. anyone have any ideas?
Old Feb 18, 2016 | 08:07 AM
highonpottery's Avatar
completely wrong section.
likely need to rotate your distributor one tooth over to get the adjustment range you require.
Old Feb 18, 2016 | 02:39 PM
Terrys87's Avatar
Sounds like you are a tooth off. I think you have a 20r and think the following video will work for yours. You may want to check to make sure. The rotor should be at the 11 oclock position and it will rotate to the 12 oclock pistion.
Easy way to install distributor on Youtube.
Dezert_Yota86
Feb 8, 2016 07:55 AM
lguzman96
Jan 27, 2016 07:58 AM
87toyoda
Jan 21, 2016 01:55 PM
modernatony
Dec 6, 2015 02:20 PM
igor2009
Dec 4, 2015 08:54 AM
