Pre 84 Trucks 1st gen pickups
Propane on new 22r???
Old Jan 14, 2014 | 07:51 AM
JasonYota's Avatar
I have seen specific break-in oil for rebuilt engines, if you don't use that then I'd say use Dino. After it's broke in switch to synthetic.
I go anywhere from 12k to 15k miles on my DD before an oil change. The color of the oil has little effect on the condition, the consistency is what counts.
As far as the magnet I've seen mixed opinions on it. I would think it would help on a new engine being broke in, but if the engine is already broke in and you have metal in your oil, the damage is already done.
Old Jan 14, 2014 | 10:51 AM
gillesdetrail's Avatar
That is the pupose of the oil filter, putting magnets in the filter could obstruct flow and lower oil pressure. For break in you use the cheapest oil you can get and vary speed and load to seat the rings. If you are using a new cam/rockers, then a 20-30 min run at 1500 rpms is recomended (then you flush the oil).
Old Jan 14, 2014 | 12:02 PM
JasonYota's Avatar
The magnets go on the outside of the filter, not the inside.
Old Jan 14, 2014 | 12:13 PM
Black_1985_SR5's Avatar
Best oil for Toyota R engines = Brad Penn I run it in every gasoline engine i own
Old Jan 16, 2014 | 05:10 AM
  #25
well that makes a lot more sense
Old Jan 16, 2014 | 08:30 AM
  #26
jahstrength's Avatar
Or you can get a magnetic oil plug bolt
Old Feb 15, 2014 | 09:15 PM
  #27
jhearold's Avatar
Can you run a spiral adapter plate with propane? It is for a weber and you use the stock carb base with the propane kit but I think they have the same bolt spacing ?? Would it help performance?
Old Feb 16, 2014 | 07:04 AM
  #28
toastyjosh's Avatar
I like to use marvel mistery oil, 1 qt and then a good dino oil like castrol to break in a motor.
Old Feb 16, 2014 | 07:23 AM
  #29
CamTom12's Avatar
You should use a good dino oil for break-in.
Avoid friction modifiers... too slick and you run the risk of not seating your rings properly, which is like 80% of the break-in process.
Old Feb 26, 2014 | 08:24 PM
  #30
jhearold's Avatar
Should be able to drop the engine in tomorrow! My propane kit should also be here! So excited! I have been taking my time to do this one right!
Old Feb 26, 2014 | 08:26 PM
  #31
jhearold's Avatar
Some more pics of it!
Attached Thumbnails Propane on new 22r???-image-1674344850.jpg   Propane on new 22r???-image-2982177866.jpg
Old Feb 26, 2014 | 08:50 PM
  #32
kawazx636's Avatar
Merry Christmas!!!!
Old Feb 26, 2014 | 09:06 PM
  #33
jhearold's Avatar
Omg.... Hahahahaha everyone makes fun of me for that.... I was hoping no one her would bring that up!!! Hahaha today I have had 2 people say that
Old Feb 27, 2014 | 05:01 AM
  #34
kawazx636's Avatar
How about Viva la Mexico??
Old Feb 27, 2014 | 05:08 AM
  #35
jhearold's Avatar
Hahaha I really screwed this one up! So much for the bad ass engine.... Should of gone with a different color other then that green!
Old Feb 27, 2014 | 05:38 AM
  #36
kawazx636's Avatar
Hey man, it's your thing, do it. I have actually seen a lot worse
Old Feb 27, 2014 | 05:47 AM
  #37
Bingle's Avatar
Hey, I like it. Mostly. I used the same (or close) green on my block and pan. I only have red spark plug wires and that's borderline too christmas for me. If you like it then it's bad a$$. Haters gonna hate.
Old Feb 27, 2014 | 05:50 AM
  #38
Bingle's Avatar
Besides, Kawa you should love it. It's pretty close to Kawasaki green! That's part of the reason I used it, always had a soft spot for kawa green.
Old Feb 27, 2014 | 06:30 AM
  #39
kawazx636's Avatar
Do love me some Kawasaki green, but only my race bikes were green. My street bikes were always black.
Old Feb 27, 2014 | 06:38 AM
  #40
jhearold's Avatar
Hahaha no I didn't care what colors I was gonna use.... Just wanted light colors to give away oil leaks and re green I ordered was lime green..... But not so much in reality
