Pre 84 Trucks 1st gen pickups
My '83 has pieces of plastic in the oil pan
Old Aug 12, 2007 | 07:37 AM
mrtejman's Avatar
Question My '83 has pieces of plastic in the oil pan
I just bought an '83 pickup and there was noise coming from the block, when I dropped the oil pan I found about six pieces of plastic about 2"-3" long.
Does anyone have any idea what that might be from?
Old Aug 12, 2007 | 07:39 AM
dropzone's Avatar
Fossilized
Probably from the plastic timing chain guide. time for a new timing chain etc.
check with ted at http://www.engnbldr.com/
Old Aug 12, 2007 | 08:12 AM
scrid's Avatar
plastic pieces
Lets see some pics of them if possible.
Years ago I was adjusting valves on my service pickup with a 22r, and accidently dropped my feeler gauge. That damn thing went right down one of the oil return holes into the pan.
I always wondered if anyone ever found that gauge years later.
Funny how crap finds it's way into those engines.
When I replaced the engine in my 94' 4runner, I was cleaning out the oil cooler and found a couple pieces of broken taillight lens in the coolent side of it. Wierd stuff.
Old Aug 12, 2007 | 02:58 PM
slacker's Avatar
your engine is making noise you say ???
I would guess your t/c guides as well , The noise is now the chain slapping up against the cover .. It will soon wear a hole in it , if it hasnt already .
Old Aug 12, 2007 | 03:43 PM
ewong's Avatar
Only one thing
I thought the 83 had the dual row timing chain that does NOT have plastic guides...
Old Aug 12, 2007 | 04:07 PM
slacker's Avatar
Originally Posted by ewong
Only one thing
NOPE ... it is convertable to a double chain ! .. but the 81 , 82 and 83 and up -> has the single chain and plastic guides .
Old Aug 12, 2007 | 04:44 PM
ewong's Avatar
Ah - thanks for the clarification...
Later blocks like the 22RE are also convertable but for alot more money
-- custom chain
-- machined front cover
(LC Engineering Kit)
The dual chain uses metal backed guides....
Old Sep 9, 2007 | 09:45 AM
mrtejman's Avatar
Yep, snapped timing chain guides
Old Sep 25, 2007 | 08:21 AM
supra89t's Avatar
Can you clarify? I have seen some sites that say that the '81 have dual row and metal-backed guides. IIRC, my '81 does have the dual row, but I have never seen the guides. Even if they are metal-backed, they still have plastic bits that wear through and fall into oil plan, right? The difference is that now the chain is riding on the metal backing instead of the timing cover if you have the metal backing. Once you clean the bits out of the pan, it should be safe to run the motor without the plastic parts of the tensioner as long as it has a metal backing, right?
Old Sep 26, 2007 | 05:44 AM
supra89t's Avatar
OK, I checked last night. My '81 has dual row chain, metal-backed chain guides. My dad bought the truck in '84 with 20k on it. So unless it had a timing chain issue before then, that should be original timing gear. My chain has worn all the way through the plastic on the driver's side guide, but the metal is now guiding it. I guess this accounts for the rattle on startup. I couldn't get the oilpan off to save my life, but the guides didn't look like they broke apart, just wore through, so I think the oilpan will be fine. I will find out (hopefully) this weekend when I pull the motor and take a bigger coaxing wrench to the oilpan while it is on a stand.
dumpster84
Apr 30, 2016 06:03 AM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
