Pre 84 Trucks 1st gen pickups
My 82 toyota Long Bed SR5
Old Mar 16, 2011 | 10:17 AM
JustDSM's Avatar
Ducatipaso, I've got a factory one out of a '80. I'm unsure of if it works, but it's yours for shipping if you'd like to try it out.
Not to hi-jack, but that rear cab liner we talked about in another thread is no longer avail. I do believe I saw one for sale for $40 on the Marlin Crawler forum.
Old Mar 16, 2011 | 03:08 PM
js894x4's Avatar
Originally Posted by pholife
looks great! I think i saw on craigslist in garden grove area if I recall.
what happen to the old wheels? i might be interested.
4runner being parted out in stanton....is that the one on beach blvd?
thanks....
1. i still have them i case i need spares
2. yes on beach
Old Mar 16, 2011 | 03:11 PM
js894x4's Avatar
Originally Posted by ducatipaso
if you ever decide to get rid of that radio, let me know. I'm seeking a period correct or factory unit for my truck.
radio doesn't quite work ir turns on and off by itself i just have it for looks for now i might take it out but i want to find another dash so i can cut it out and install an aftermarket radio
Old May 17, 2011 | 07:12 PM
js894x4's Avatar
I just removed my transmission. I have a friend who will rebuild it for me for a reasonable price since he lost his job and is working out of his garage. I'm replacing the clutch although it still looks good and resurfacing the flywheel, replacing the rear main seal since it will be a while before i take down the transmission again. I also just installed both tail light. a friend brought the from Guatemala about $3 each new (taiwan) one of mine was faded.
Old May 17, 2011 | 07:33 PM
  #25
dropzone's Avatar
Fossilized
I have always loved these Enkei rims...nice
the sami Hubs were a direct replacement?
Old May 18, 2011 | 06:38 AM
  #26
83's Avatar
83
Just FYI, on the rear main...this is Marlin's (Marlin Crawler) advice on the rear main:
"4. Rear engine seal.
In almost all cases the rear seal will not be leaking. After removing the clutch assm and flywheel, and then the backing plate, carefully inspect the rear seal around the hub of the crank. Is it actually leaking, or is it the capillary action of the leaking valve cover rear half moon seal that was running down the back of the engine.
If it is not leaking, you have two choices:
A. Replace the good seal;
This is risky business. Remove the rear real, sand the hub of the crank, prelube the sealing lip of the seal and install it being very careful not to damage the seal during installation by hammering directly on the seal body. Then you need to hope that the new seal does not line up and contact directly on the worn area that was caused from the old seal. Never use a stainless steel speedy sleeve on the front or rear hubs of the crankshaft. They are very difficult to install straight, and because the steel is so hard, the seal does not lap in correctly and will always leak in time.
B. Leave the good seal alone;
This is the way Marlin advises. If the seal is not leaking, leave it alone. It has properly lapped in and is doing its job. I leave it until the motor is completely worn out and then you can properly replace it at that time. I have replaced more leaking seals due to customers who have installed a new seal when they did a clutch job. Only to develop a new leak later."
But of course it's up to you.
Old May 18, 2011 | 07:31 AM
  #27
ducatipaso's Avatar
wanna swap? I have a cut dash panel I'd like to go original.
Old May 18, 2011 | 03:58 PM
  #28
js894x4's Avatar
yes i locked them and they engage just fine. Plus they are the same brand as the toyota hubs
Old Jun 2, 2011 | 06:17 PM
  #29
dougstoys's Avatar
Awesome rims! Have you had any luck on the decals (hood & sides)? I would love to put those on my truck after it's painted.
Old Jun 3, 2011 | 06:13 PM
  #30
js894x4's Avatar
There is a website you can order them from http://www.jamesdeancreations.com/toyota.htm. $250 for the set but i'm still working on other thing now paint and decals will come later. Im having the transmission being rebuilt by a friend now.
Old Jun 3, 2011 | 06:18 PM
  #31
js894x4's Avatar
i want one i can butcher but still keep the original.
Old Jun 4, 2011 | 08:18 AM
  #32
dougstoys's Avatar
Love those stripes, not so much the price. I bookmarked the site because at least I can get the tailgate decals.
Old Jun 4, 2011 | 05:27 PM
  #33
js894x4's Avatar
i guess that for being the only place that has them is not too bad for a whole set. plus they look great once they r on.
arlindsay1992
Jan 23, 2024 01:34 PM
DanStew
Jun 29, 2015 10:46 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
paxanders
Jun 21, 2015 06:29 AM
