Pre 84 Trucks 1st gen pickups
My 81 2 Wheel drive is one inch higher on the driver side?? I have 3 inch lower block
Old Apr 19, 2018 | 09:06 PM
Paycek's Avatar
I can not figure out why my truck sits leaning higher on the drivers side as I have exact same leaf springs in back with 3 inch lowering blocks.
I have tried to adjust my torsion bars to even it but has not worked. I am about an inch lower front and back on the passenger side. Not sure where to go from here??
Old May 10, 2018 | 05:23 PM
itsivxx's Avatar
Right off the bat I would remove the springs and check height from one to the other. I was able to get about 3/4" adjustment to get mine perfect. I ended up having mine re-arched 1" lower and to find out I had one sagging spring. Added a leaf, re-arched and adjusted my front bars. 100% perfect. I own the 81 Toyota 2WD as well
Old May 14, 2018 | 09:28 AM
Paycek's Avatar
Thank you for the message. It was my first and figured no one had any input.
I will pull the springs and check them as suggested.
That will only cover the back though, correct? For the front, no matter how much I play around with adjusting the toresion bars I can't get the front to level out either.
Nice rig, looks exactly like mine!
Old May 14, 2018 | 09:57 AM
itsivxx's Avatar
As long as the rear springs are arched at the same degree...the front torsion bars will make up the difference. I was having the same issue, I removed my springs, added a leaf and re-arched. It takes some time running around the truck, checking the height after each adjustment on the front to get it perfect.
Is your's Yellow?
Old May 14, 2018 | 07:24 PM
Paycek's Avatar
OK, will do. In the mean time I am posting another thread on the carb and fast idle adjustment.
No, see my new emoji, it's a blue SR5. Thanks much for the insight and look at my next question if you have a possible answer on that too!
Whitemoneypit
20
Nov 1, 2015 10:20 AM
rubronthroad
Nov 28, 2012 12:08 PM
animator
7
Jul 12, 2007 06:57 AM
li_runner
Apr 26, 2006 09:39 PM
