Pre 84 Trucks 1st gen pickups
Looking for a SOFT ride
Old Dec 18, 2018 | 06:28 PM
  #41
swampedout's Avatar
5 Year Member
This thread is 6 years old.
But I am going through my suspension too and from what I have read from others, the best value for leaf springs is the ome's. $100 per pack, $400 total plus bushings and whatever other hardware you need to replace.. Not a bad price for a quality product.
http://www.lowrangeoffroad.com/toyot...ion-parts.html
There is varying opinions but most other brands seem to wear out quickly. You can also check parts yards and craigslist. I know there's a guy in Pensacola selling springs right now, but that could be a bit of a drive for you.
There's also deaver springs and alcan if you got $$$
Leaf springs need to get replaced first, they are holding up the weight of your truck and since you already got shocks, your problem is almost solved.
Old Dec 19, 2018 | 06:22 AM
  #42
rickc5's Avatar
When I first bought my '83, I thought the ride was horrible--like having NO suspension. My truck came with a 2" lift, so the springs had been changed. I took the truck to our local spring/suspension shop (The Spring Works in Grand Junction, CO) and told them that it rode too stiff. One of the mods they made was to shorten the leaves in the front spring pack to reduce the stiffness. It actually worked, but only slightly, as they also replaced all the shocks with Skyjackers (extra length needed due to the lift), which conversely stiffened the ride a bit. It still rides like a truck, but it's tolerable. More than one way to skin a cat.
Old Jan 1, 2019 | 09:22 PM
  #43
New Red Truck's Avatar
Well, I just got this truck back on the road after sitting dead since 2014. Now it's back to daily driver status and my original "appreciation" of the front suspension is once again on my mind. The Old Man Emu springs seem like the way I would tend to go but I'm wondering if it's possible to reduce the amount of lift they confer? Maybe pull one of the springs from the pack? I'd be happy with like 1" of lift, just to increase the free space above the bump stop. I have stock sized tires and probably will as long as it's a daily driver so I don't need or want much lift at all.
Incidentally, part of the revival process was desmogging the engine and adding a Weber and add me to the list of happy customers on that front!
Old Jan 2, 2019 | 08:54 AM
  #44
NYHumpinUtah's Avatar
Pics?
Welcome
83yotastockR
11
Nov 10, 2015 06:54 AM
ktm192k
Oct 1, 2015 08:47 AM
Brodetski
Sep 30, 2015 11:50 PM
oldblue
Sep 28, 2015 04:07 PM
