Pre 84 Trucks 1st gen pickups
Leaf Spring Help
Old Jan 25, 2006 | 07:52 PM
JerryD's Avatar
Leaf Spring Help
Ok, I have an '83 truck. On the front I have 3" lift springs from skyjacker. What springs can I get for the rear and not have to move my rear spring hangers? Thanks.
Old Jan 25, 2006 | 08:08 PM
kyle_22r's Avatar
to make it level, use 2" springs in the rear. skyjacker and downey make bolt-in springs.
Old Jan 26, 2006 | 11:09 AM
JerryD's Avatar
I've read a lot of threads about different leaf springs, my other thought was the 63" chevy's and just relocate the spring hangers. This is going to be a daily driver as well as a trail rig, and I live in MO, so not going to be doing an rockcrawling. Any opinions or ideas on spring setups for the rear would be appreciared. I will probably end up with an all pro style flat bed on it as well.
Old Jan 26, 2006 | 11:12 AM
Intrepid's Avatar
From what I have read, the Chevy springs are the best way to go, good flex and they ride nice. I say go for it.
Sky Manufacturing makes kits for them, all you have to do is get the springs.
Also, why spend the money for an all-pro flatbed if you are only doing minor wheeling?
Old Jan 26, 2006 | 03:34 PM
JerryD's Avatar
The reason for the flatbed is because right now there is no bed, it is still in project phase. It isn't even running right now, I'm getting ready to do an EFI conversion on it. I also just like the way the flatbed looks, and I think it will be easier since I have to mount the EFI tank in a different location.
Old Feb 12, 2006 | 02:07 PM
JerryD's Avatar
I decided to go with downey's in the rear. Got the springs and shackles in last week. Waiting on a U-bolt flip kit from Marlin. The U-bolts were pretty rusted and the thing that holds them in place was rusted in half, so I thought I would just go with the flip kit. I should be able to put the new springs on next weekend. I'll try to post some pics then.
Old Sep 16, 2008 | 04:34 PM
King of Springs's Avatar
I know thesuspensionking.com can make you 3" lift springs for the rear of your 83 Toyota pick-up. They would bolt right in, I believe stock part # is TOY17 you would need. Then you will have to call them or email them. They can make them special with a 3" lift. They will probably cost you around 180.00 each bushed for 3" lift springs. They can be made in about a week.
Good luck.
Old Sep 16, 2008 | 06:06 PM
dropzone's Avatar
Fossilized
Old Mar 15, 2010 | 06:09 PM
Slick's Avatar
I have a 78 toyota im converting to 4wd whats the easiest cheapest way to convert the rear from spring under to spring over..
Old Mar 16, 2010 | 08:48 AM
dropzone's Avatar
Fossilized
easiest way is to get a 79-83 4wd axle that already has the spring mounts on top of the axles, usually fairly cheap since people pulling them to convert to a wider '86 plus IFS rear axles. but that also depends on what donor axle you are using upfront.
several venders such as wab-fab, trail-gear have spring mounts for cheap: $29 + shipping
http://www.trail-gear.com/rearhangers.html
downside you need to weld.
Old Mar 16, 2010 | 12:06 PM
83YotaNator's Avatar
Chevy 56in springs (shorter ones, not 63's) Should bolt in and work well with bout 3in of lift
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
