Pre 84 Trucks 1st gen pickups
L52 swap in morning TIPS!!!
Old Aug 12, 2013 | 12:22 PM
83's Avatar
83
Originally Posted by catfish21
Well I guess I'm gonna cross my fingers cause I replaced it and I don't think it was leaking, and I did feel the grove your talking about on the crank. I wish I would have known this ahead of time and I did put a Toyota seal back in so I just hope and pray. I have a brand new tranny now and clutch and I was hoping to never have to do that again until way down the line
Yeah I wish I had been around internet when you first posted this. You're likely fine. I've never replaced that seal, and I think there was talk about it on Marlins site because so many people, when doing the clutch or tranny, figure "I'll replace the rear main while I'm in there", not knowing it's better to leave well enough alone, when it comes to that particular seal. And just because you can replace a clutch doesn't mean you're any good at properly seating seals.
But I don't know what the sucess rate it...
I will tell you...doing a tranny/clutch job once and hoping to never do one again is an unrealistic idea. I thought the same thing. I had my Marlin L52HD in and out 3 times.
You may have better luck, but...if you keep the truck long enough, you'll pull the tranny again. Think of everything you do as a learning experience so you can do it faster and with less stress next time. Cause with old trucks like ours, there will probably be a next time, even though you think when you rebuild and replace something "well, that won't need to be done for another 30 years!".
It's rarely worked out that way for me...rebuilt parts rarely seem to last like a new factory part, and once you start taking your truck apart, it's never quite the same again. It's now much more your truck, but once you have things apart, they somehow have a way of needing to come apart more often...
westonian18
May 1, 2020 06:38 AM
93toyoguy
Aug 2, 2015 07:41 PM
WellsR
12
Jul 31, 2015 03:27 PM
redneck17
Jul 17, 2015 07:44 PM
Hamonacracker
Jul 17, 2015 08:33 AM
