Pre 84 Trucks 1st gen pickups
Installing '80 20R in my '83....couple questions
Old Jun 14, 2011 | 05:47 PM
southernZ's Avatar
I know it will "bolt up" just curious to see if there will be any fitment issues (throttle linkage, electrical connectors, etc.) I plan on installing the power steering pump off of the blown 22R on the 20R...To those who have done this ant tips/suggestions?
Old Jun 14, 2011 | 05:52 PM
slacker's Avatar
no fitment issues .. just some wiring differances
power steering systems are the same , so dont bother with that unless there is an issue ?
20R is a bit of a step backwards , as there is less power ..
your best option is the put the 20R head on the 22r block ...
Old Jun 14, 2011 | 06:03 PM
southernZ's Avatar
i would love to but the 22R has a rod poking out of the block....
Old Jun 15, 2011 | 09:28 AM
southernZ's Avatar
What electrical differences are there?
Old Jun 15, 2011 | 03:25 PM
slacker's Avatar
20r is a manual "antifreeze" plumbed choke , where the 22r is an electric choke .. so you'll have to plumb/splice in the choke . if you have the oil pressure guage , you will have to swap that
actually , I think thats it ..
Old Jun 15, 2011 | 04:28 PM
dropzone's Avatar
Fossilized
A lot of the connections on the earlier engine will have round plugs.
82-83 will have square plugs if memory serves me correctly.
Old Jun 16, 2011 | 09:12 AM
southernZ's Avatar
Thanks guys....just trying to get all my ducks in a row before the install.....is a "heavy duty" clutch worth looking at on a dd / hunting truck? I want to put the best parts on it as possible while the engine is out...thinking on putting a header and doing away with the egr etc.....( the vacuum lines are a mess on the engine)...
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
calderp
Jul 27, 2015 09:58 AM
rushw
Jul 18, 2015 01:46 PM
Coreyr384
Jul 10, 2015 11:13 AM
