Pre 84 Trucks 1st gen pickups
Ideas for mounting 1st gen rock sliders
Old Apr 25, 2012 | 06:40 PM
YotaBoy83's Avatar
Question Ideas for mounting 1st gen rock sliders
So my 83 long bed sr5 is in need of some sliders and I was looking at some ideas and at my truck today I know exactly how I want it designed but I am unsure on how to mount them to the frame without sacrificing much ground clearance. I have seen where people mount a plate in the side of the frame and weld out from there but on my truck if I went straight out from the frame I would hit the body any other ideas on mounting please? Pics or links would be great I have searched but cannot find anything.
Old Apr 25, 2012 | 06:44 PM
YotaBoy83's Avatar
I also have no body lift and don't plan on one hate the look
Old Apr 25, 2012 | 07:15 PM
nMe_814's Avatar
im not sure if this helps you as far as the ground clearance. i have a 3rd gen pickup and had the same problem. so this is what i did.
Just angled it down.
Old Apr 25, 2012 | 07:18 PM
ThatGuy1295's Avatar
just like that. But i always put a gusset on top of the tube to support the tube to plate connection. And theres no reseon to angle the connecting tube upwards. Might as well just run off the rock bar 90 degrees to the bottom of the plate, and have more room for the gusset.
Old Apr 25, 2012 | 07:25 PM
Kind of hard to see in this pic. But theres a gusset.
YotaBoy83's Avatar
Oh wow can't believe I never thought of that looks like a great idea I'll add gussets too. Thanks for the help I'll post pics once I get it done
Old Apr 26, 2012 | 03:34 AM
nMe_814's Avatar
i did it that way so it would be far enough away from that pinch weld. its only about 3/4 inches away. i forget the measurements, but if i remember right, i would have been too close for comfort if i had come straight off at 90deg. at the bottom of the frame.
i didnt want to be so close that it might start making noise against that pinch weld.
Old May 7, 2012 | 08:07 AM
dirtdobberoffroad's Avatar
on my 82 I was figuring on using a holesaw and cutting through the rocker panel!!!!! but this changes every thing thanks for the pic, I cant belive something so easy and I over looked it.
Jun 1, 2021 01:51 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
jon.r
Jul 11, 2015 03:34 PM
coryc85
Jul 6, 2015 04:07 AM
