Pre 84 Trucks 1st gen pickups
Help. 77 pickup gm ignitor swap
Old Sep 15, 2019 | 03:18 PM
CMiller's Avatar
I bought a 77 toyota pickup with no spark. I figured it would be alot easier to do the GM module bypass. I noticed my distributor was the points style distributer so I found a distributer on CL from a 22r, it has 2 wires. Still no spark. I'm sure I have the ignition module and coil wired correctly. Red distributer wire to G, white to W, - side of coil to C, and B to the + side of coil and 12v. For 12v power im using the old (black w/ yellow strip) wire that went from the fuse box to the resistor and then to the old coil. I have tested it and I have 12v when the key is on.
The only possible problems I can see is that either I have a bad ground, but I tested the resistance from the module to negitive of battery and there is connection. Or the distributor I bought is bad.
How can I test the signal coming from the distributor? How can I test that my GM ignition module is good? How can I test my coil is good?how can I test that my coil is charging? Would it be ok to run the ground for the module directly to the battery.
Old Sep 16, 2019 | 08:13 AM
13Swords's Avatar
5 Year Member
I've done this conversion & do have a write-up on it on here. I'll take your questions in order.
Wiring - The Black with Yellow Stripe wire is the correct wire for power feed, but you mention it used to go to the resistor. You aren't using the old resistor in this new setup are you? If you are, remove the resistor from the circuit & connect/splice those 2 wires together. The HEI module needs full 12 volt power & the old ballast resistor will cut that down to something like 9 volts, & the module will not work, or work poorly. The ballast resistor is only there to save your old points from wearing out too fast. Now that you have eliminates the points, you don't need the resistor. And yes I do know that original & replacement ignition coils will have "FOR USE WITH EXTERNAL RESISTOR" printed on the coil body. Ignore it. You can run those coils at full 12 volt power & they will be fine. It's only printed on there because they expect that you are still running points. Good that you tested power with a meter, but if you have the resistor still in circuit & probed where the Black/Yellow wire goes into it, you're only reading battery power. If you measure after the resistor (what's coming out of it) you'll probably see less voltage than 12 volts. Ditch the resistor.
Did you measure power at the Module with the key in RUN position only? Did you also check to see if you had power at the Module while cranking (key START position)? Did you test for power on the Black/Yellow wire in BOTH the RUN and START positions?
Ground - A solid ground is critical to having the HEI Module work. The Module works by switching the Ground on & off to fire the coil. This runs from the Modules Ground Point, thru the switching transistor inside, then out to the coil via the C terminal. The correct grounding point on the Module is the eyelet hole closest to the B & C terminal side of the Module. it is on the right in this picture:
Note the larger eyelet with the little tab on it. I recommend a 14 gauge (or larger) ground wire with eye terminals of the correct size. I have 1 eye terminal under the head of the hold-down screw that goes into that right eyelet. I have the other end of the ground wire eye terminal between my fender (paint cleaned off to bare metal) & the mounting bracket for the voltage regulator, with the regulator mounting bolt holding it all down snug.
You may be reading resistance from Module to Battery Negative, showing a connection, but that connection may not be solid. It would be OK to run a ground from the Module direct to Battery Negative, but it's really not necessary. That's a long run of wire which could add resistance you don't need. You just need to run it to a solid body or frame ground (as previously described) somewhere near the Module's location. A good alternative location is the secondary ground wire that runs from the rear of the head to the firewall. This is basically a direct connection to Battery Ground, through the engine block & head. Make sure all connections are clean & tight,including your spade lug terminals on the Module tabs.
HEI Module Testing - Almost any auto parts store offers free testing (Auto Zone, O'Relley's, etc.) & they can check the module for you. What Brand & Part # of Module did you buy?
Ignition Coil -
The parts store can also test your ignition coil for free. If you have a Volt/Ohm Meter & know how to use it you can test it yourself. You measure the Primary & Secondary Resistances. Primary is measured on the + & - terminals. Secondary is measured on the + terminal & the Center Coil Output terminal. On the Primary reading, if you do not have a self-zeroing Ohm Meter, you need to connect your leads together 1st to find out what resistance is in your leads. You then subtract this from the reading you get on the + & - terminals to get the correct measurement.
The specs for your ignition coil should be:
Primary Resistance - 1.3 to 1.7 Ohms
Secondary Resistance - 6,500 to 10,500 Ohms
These are the stock Toyota specs for the ignition coil for '75 to '79, & the stock coil will work fine with the HEI Module. PLEASE NOTE - These specs are "cold specs". A faulty or failing ignition coil can still read good (within the specs) cold, but be out of spec once put to use & "heated up". If in doubt, just get a new quality ignition coil. I recommend the Standard UC12. DO NOT CHEAP OUT ON THE COIL! I have previously used a cheap coil & it didn't last 6 months, plus it wiped out the Module. The main cause of ignition module failure is a failed or failing ignition coil with too high a secondary resistance. Some of the windings inside can also break over time due to heat & vibration, in which case you have a broken circuit so no electricity will pass at all, so no spark.
Distributor - The main thing we need to look at is the Distributor Pickup Coil. This is a "trigger" for the Ignition Module. The 2 main factors are the coils resistance & the air gap setting between the Reluctor Ring ("spiked" ring inside) & the Coil's face. When one of the "spikes" passes the coil's face, it generates (induces) a low voltage signal, which is sent to the Ignition Module via the wires & triggers the Module. Average voltage on this action is usually less than 3 volts.
Pickup Coil Resistance - Spec is 140 to 180 Ohms. You can measure this with an Ohm Meter at the 2 leads coming from the distributor (Red & White wires). Disconnect the Red & White wires from the Ignition Module before taking a reading. If the reading is anything above 160 Ohms I'd say to replace the coil with a new one & set the airgap. That coil is also subject to aging & higher resistance from heat. Higher resistance can causes a loss of signal voltage & the Ignition Module won't trigger.
Pickup Coil Airgap - The spec for this is .004" to .012". If the gap is too big it won't generate a signal or the signal will be weak. Check the gap size with feeler gauges to find out what it is. Or if you don't have feeler gauges you can use a fairly new & crisp dollar bill to check it. The paper is .0043" thick, so just fold in half & stick it in the gap to check. I set mine up this way & it runs great. The folded bill yields .0086" so that's about perfect. Also easier than using a steel feeler gauge, because there is a magnet in the pickup coil that could cause you problems in getting an accurate check (steel gauge sticks to magnet).
Pickup Coil Signal Test - Disconnect Red & White wires from Ignition Module. Hook up your Volt/Ohm Meter set to 20 volt DC range. Crank engine over & watch the meter. You should get a pulsing reading of around 3 volts or more. Less than 3 volts and the airgap is out of adjustment or the coil is going or gone bad.
That's everything I can think of at the moment. Just go through everything in order step by step & you are likely to find the problem. Once setup correctly this system works like a charm on these engines. Let me know what you find out.
PS Are you sure you installed the replacement distributor correctly?
Old Sep 16, 2019 | 07:56 PM
CMiller's Avatar
Update: I tested the pickup coil and it is bad. So there we go. But I also tested the voltage coming to the module and I have 12v with key in on position and when I crank it it drops to 10v. Probably just because the starter is running and then will return to 12v when the engine starts right? I tested the power to the coil by putting one probe on the the b terminal of the module and the other probe to ground. This is correct? My module is a napa brand, I can get the pn tomorrow. My module is grounded with a screw in the right hole. Im not using the resistor either. I noticed that the fuse in the fuse box for my ignition power wire has a 30 amp fuse but in the diagram i see has a 15 amp fuse, which is correct.
Old Sep 17, 2019 | 06:18 AM
13Swords's Avatar
5 Year Member
What's the condition of your battery? A good battery should have at least 12.6 volts at rest (engine off & not charging). Yes, voltage will drop when cranking as the starter motor takes a decent amount of power to operate. Once the engine starts you should be reading charging voltage of 13.7 to 14.7 volts. Your test for power to the coil is not correct. What you describe is testing for power at the B terminal on the Module, because that is where you are probing. You have to actually probe the coil (+ terminal) to test for power to the coil. Does this make sense? Doing it the way you describe "skips over" the wire connection from the Module's B terminal to the + terminal on the coil. Any connection between two points may or may not have a problem. You have to check every link in the electrical chain when testing/troubleshooting.
The NAPA Brand ignition modules are good but overpriced. NAPA has them made for them by Standard Motor Parts, and the same part with the Standard brand name on it is usually half the price. I'm guessing that you have the NAPA/Echlin #ECH TP45. This is the same module as the Standard LX301.
You say the Module is "grounded with a screw in the right hole". Right as in correct? Or right vs left? This isn't clear. You didn't mention if you ran the ground wire I described? Also, did you get a heatsink for the module or no? It needs one. Change out that 30 amp fuse for a 15 amp. The "bigger" fuse could cause problems, like a fire, if you ever have a short in the ignition circuit.
Old Oct 5, 2019 | 10:26 AM
CMiller's Avatar
My truck is running great. Had a bad ground. Slapped a weber carb on and she sounds good. With the GM ignition swap, what spark plugs and gap should i be using?
Old Oct 6, 2019 | 06:46 AM
13Swords's Avatar
5 Year Member
Great to hear. Good ground to the module is crucial to it working right. Original Stock spark plugs for the 20R are listed as:
NGK - BP5ES-L or
NipponDenso - W16EP
I am currently running the the Denso W16EXU plugs but any good quality plug should work for you. Here is a reference list for your '77:
https://www.rockauto.com/en/catalog/...park+plug,7212
Gap is .032", or 0.8mm.
Old Dec 11, 2024 | 10:20 AM
101 vintage's Avatar
IM STUCK with the GM igniter SWAP
I have everything hooked up correct from all the YouTube and this form the issue I believe im having is one not getting spark due to low voltage from the keyed on power I have 12+ volts at the battery but the black and yellow wire is just barely 11 volts I don’t have a resistors or any ballasts before the black and yellow wire or just goes to the ignition switch that also is under 12 volts I’ve checked my grounds and connections 1000 times
PLEASE HELP
UPDATE
just hard soldered every connection and now I have 12 Volts but still no spark
Old Dec 12, 2024 | 05:18 AM
13Swords's Avatar
5 Year Member
PLEASE HELP
UPDATE
First, how are you determining that you aren't getting spark? Please describe in detail what you're doing to check this. You say you're getting 12 volts to the module(?). Is this with the key in the RUN position, START position, both?? I'd also be interested to hear about any test results of what the voltage is while cranking (Start circuit). (See Note 1 below). Have you tested for voltage at the ignition coil as well, in both the RUN & START conditions?
If you have positively confirmed that you are getting zero spark, but getting 12 volts at the module, it could be several things. But if you've done everything else correctly, it's most likely one of two things. Either the module itself isn't good or you have an issue with the Pickup Coil in the distributor. Let's start with the Pickup Coil.
Use an Ohm meter to check the coil's resistance at the coil's connector. The factory spec for this is 130 to 180 Ohms cold. Any cold reading over 160 Ohms might indicate that the Pickup Coil is failing. Pickup Coils can start to fail over time due to heat cycling fatiguing the copper wire in the coil, creating higher than spec resistance, which would reduce or block any induced signal the coil could create. Improper or no signal to the module = weak or no spark.
Check the air gap of the Pickup Coil. Too narrow or too wide (especially) of an air gap will either provide an incorrect signal to the module or weak or no signal to the module. The correct spec for the Pickup Coil air gap is 0.08" or 2mm to 0.16" or 4mm. This is measured with one of the "vanes" on the reluctor pointing directly at the center of the coil like this:
Correct alignment to measure & set Pickup Coil air gap.
I run my air gap at 0.12" or 3mm, right in the middle of the spec, with no issues. The two screws shown in the diagram above hold down the Pickup Coil. You have to loosen both screws to adjust the gap. I highly advise leaving the correct size feeler gauge in the gap when when tightening down the hold-down screws. Once you secure the Pickup Coil you should be able to remove the feeler gauge with just a little drag felt on the feeler gauge. I've done this with common steel feeler gauges without issue. If you want to do it the "factory way" with non-magnetic feeler gauges, NAPA has a set of brass feeler gauges for about $5, NAPA Part #: SER 2223.
Other possible issues:
Ignition Module damaged or not working. I messed up two LX301T modules when I did my conversion. It wasn't the module's fault but mine for using cheap chinese ignition coils that developed high secondary resistance, which ended up cooking the modules. It might be a good idea to take the module out of the truck & get it tested to make sure it's OK & so you know for sure the module isn't the issue. I usually go to O'Reilley's for this, they test for free.
Bad Ignition Coil. I know from your previous messages on Youtube that you are using a new UC-15 Standard Motor Products coil. New parts can sometimes be bad right out of the box, and I wouldn't expect that of an SMP part, but it's worth checking to be sure. Use an Ohm meter to check the Primary & Secondary resistances. The spec on this is Primary 1.3 to 1.7 Ohms, Secondary 6500 to 10,500 Ohms. The lower the spec the better on Secondary. Anything above 9400 Ohms cold on the Secondary and I'd suspect the coil to be damaged, defective or failing.
(Note 1): If you use a volt meter to check the START (cranking) circuit, and see something much less than 12 volts with the key turned & held to Start, you could have a worn/failing ignition switch. Over time & use the contacts inside the switch can get worn, pitted or corroded, all of which can lead to higher than desired resistance, which will cut down the voltage going to anything running off either the RUN or START circuits. Our trucks are more than 45 years old* so this is a distinct possibility and worth checking out.
*This goes for darn near everything else on the vehicle. I've learned the hard way not to assume ANYTHING with older vehicles, always check to be sure.
Unlikely but possible - Check your Engine fuse and it's holders for dirt, corrosion or damage, which can also cause an excess resistance problem. It's a 15 Amp fuse second from the bottom on your fuse block.
Just take your time & work through these things one at a time. The HEI module conversion system is fairly straightforward so whatever is getting in the way of it not working shouldn't be that hard to track down. It's just a process.
If you want to respond/communicate through this thread that would be good. I get email notifications anytime someone posts to my threads.
Old Dec 12, 2024 | 02:55 PM
Currently
I have a new distributor so shouldn’t be anything with that , I’m checking spark by holding wire with plug near a body or block ground
I have my test light on the frame and when I touch C on the module it lights up as well as B which is going to keyed power so that’s correct but I have no clue why my C is powered so that also make my ( - )on my coil powered as well I believe this isn’t correct if so then what should I do
i Have tested my coil it tested good
I also set my gap to 3mm
when cranking I has 9volts at the module
Old Dec 13, 2024 | 05:38 AM
13Swords's Avatar
5 Year Member
You should Ohm out the Pickup coil with an Ohm meter anyway to be sure it's in correct spec. Take nothing for granted. Also just to be clear, holding the spark plug "near" a body or block ground isn't good enough; it actually needs to be in physical contact with ground. Then watching the plug electrode for spark.
I'm just trying to be as clearly specific here as possible.
Of course your ignition coil is powered when you have the Ignition switch on RUN. The coil has to be powered to develop a "charge" current. What you need to test for is if the module is turning the coil off and on. To explain just in case....
What contact points or ignition modules do is regulate when the ignition coil is either powered or not. In other words, turns the ignition coil on or off. ON, it builds charge, OFF, the magnetic field in the coil collapses and the built-up charge is released through the center post/terminal of the coil.
Which then goes by the center wire to the center post/terminal of your distributor cap.
There is a power transistor inside the HEI module that does the switching, and it is controlled by the presence or absence of a signal generated by the Pickup Coil.
So when you say "I have my test light on the frame" I assume that means you have attached the clip at the end of the test light's wire to a frame or body ground. With the key on (RUN), and the engine is not turning (not running or cranking), then the Pickup Coil will not send any signal to the HEI module to trigger the Ignition Coil to turn off. So of course you're going to see constant voltage in such conditions.
A better way to test is hook up the test light as you have it with the probe touching "C", and crank the engine over (START position of the ignition switch). If all is well with the Pickup Coil & HEI Module, you should see the test light cycle on & off with rapid & regular pulses.
This would prove that the Pickup Coil is generating a pulsing signal & is working.
If you then touch the negative (-) terminal of the ignition coil & crank again, you should see the same pulsing of the light. That would definitely prove that the Power Transistor is switching on & off, & that the HEI module is likely good.
Good on the coil test & air gap setting. What were the resistance readings of the coil though? Assuming you tested the coil with an Ohm meter? I need specifics if I'm going to try to help you get this figured out.
Also assuming you mean 9 volts at the module "B" terminal when cranking? Is that 9 volts measured with a volt meter or something else? Is that an exact number or rounded? Again I need specifics.
If exact 9 volts, that sounds a bit low to me. Something closer to 10 volts is more normal. If exact 9 volts I would still suspect a bad or worn ignition switch giving excess resistance, dropping the voltage.
Please also describe here exactly how & where you have the ground for the module. I ask this because 8-9 times out of 10 it's usually a ground issue that's causing a no-spark condition with these conversions.
Related: If you have an Ohm meter (and please verify to me if you do or do not have one so I know what you're working with there), check the end-to-end resistance of the battery ground cable or starp & let me know what that number is specifically.
Brown
78
Mar 2, 2024 09:53 AM
Autophysn
Aug 6, 2013 09:11 PM
4bangercraig
Nov 2, 2012 04:39 PM
wanhp225
Jan 27, 2010 04:28 PM
netwt12
Jun 24, 2006 06:13 PM
