Pre 84 Trucks 1st gen pickups
Fuel Smell from Exhaust?
Old May 6, 2016 | 11:18 PM
msane99's Avatar
rejet kit is going to have bigger jets than what you have now. need to know whats in it first then order the individual jets you want to try.
Old May 31, 2016 | 09:33 AM
GodwinAustin's Avatar
Alright well got the regulator on there and is running better but still running too rich - I leaned out the mixture until the exhaust smells ok, the truck runs great when warmed up and feels like its at the right mixture, but I get both backfiring on deceleration and a very rough idle when cold.
I suspect an air leak at the carb base plate - I suppose this could be causing the rough idle and backfire and that extra air is preventing me from leaning it out as much as the motor needs. Will report back.
Old Jun 7, 2016 | 08:22 AM
Got new cap, rotor, wires, and plugs on order, see if that does anything too - also will be checking the timing.
Old Jun 17, 2016 | 08:18 AM
so ended up advancing the timing by sound, changed plugs, cap, rotor, wires - not only did this get rid of the backfiring on Decel I was having but got rid of the fuel smell as well.
Mixture screw is around where it used to be at about 2 turns out.
Truck seems to be running really well now. No pinging or knocking as far as I can tell. Im at around 7000 feet.
Old Jun 18, 2016 | 06:38 PM
  #25
CAdot's Avatar
TransAmBandit
Mar 2, 2016 11:16 PM
crawler85
Feb 27, 2016 07:31 AM
ZRTALPHA1
Feb 21, 2016 12:12 PM
westonian18
Feb 4, 2016 01:17 PM
westonian18
Feb 4, 2016 04:56 AM
