Pre 84 Trucks 1st gen pickups
few Q's about for my 81 4x4
Old Nov 24, 2008 | 09:06 PM
4x4YOTA's Avatar
ok I have a few questions on some things I want to do to my 81 4x4
the ride in the truck is stiff, my front leaf springs have negative arch...
to fix it I am debating on OME light duty leaf springs or possibly rears up front!
Q 1 how much lift will rears up front give me?
Q 2 are OME (light duty front leafs) worth the price?
second topic
I have a 83 4x4 parts truck (parting it out) and its all there, and I am debating on dual cases but not sure if its worth it for a DD?
third topic
I have a set of 5.29 thirds (rear has detroit front is open) that I would love to run but Im still running 31s (til I can afford 33s). I drive the truck about 10 miles total everyday no more than 45-50 mph
Q 1 how bad would it be to run 5.29s with 31s
Q 2 will a detroit locker kill my truck as far as being a DD
Old Nov 24, 2008 | 09:33 PM
dropzone's Avatar
Fossilized
Originally Posted by 4x4YOTA
second topic
from your other thread:
Originally Posted by ocdropzone
If you want a dual purpose truck, than yes, it my opinion it is worth it.
but a word of caution on adding duals...
a second transfer case is just one part of the equation...
Rough estimate of adding duals to a truck. (some can do it cheaper due to their fab skills)
dual case adapter $299-350
CrossMember: $199-270
Drive shaft $200-400 ++ (depending on who you go with)
(shortening rear and lengthening front)
2nd Transfer case $75-150
(yes you have yours)
Adding duals can run up over a $1000 very easily. For me it was an easy decision because after going on a few trail runs and almost breaking stuff because I had to give it a ton of skinny pedal to get over stuff that the guys with more gearing options were able to practically idle over.
I am looking forward to having 20 forward speeds and 4 reverse
Stock 5 speed 4WD, stock 2.28 LR, 4.7 gears in crawl box and than 2.28x4.7 in lo, lo...
It really all just comes down to what you want to do with your truck...
third topic
I have a set of 5.29 thirds (rear has detroit front is open) I drive the truck about 10 miles total everyday no more than 45-50 miles per hour
I have had a couple of locked rear trucks over the years, you might notice some chirping when turning and possibly increased tire wear. (rotating them evens it out)
You get used to the driving characteristics of a locked truck after awhile...
mussy01
Dec 13, 2016 08:20 PM
redneck17
Aug 5, 2015 10:03 AM
defrag4
Jul 31, 2015 10:50 AM
PopsDad1
Jul 30, 2015 02:21 PM
pyramid
Jul 29, 2015 06:53 AM
