Pre 84 Trucks 1st gen pickups
Exhaust Gasket Install
Old Apr 25, 2012 | 10:41 AM
86carbPU's Avatar
AMS8171-APEX exhaust manifold gasket set from Autozone includes what seems to be 2 gaskets(one metal material & one cardboard material) & some kind of insulation strips. I've got the stock '86 carb, intake & exhaust setup but the rebuilt longblock has steel rockers so I got an exhaust set for an earlier(81-84)... does anyone know how to properly stack these up??? Where would the insulation go??? Here are some torque specs as a contribution:
exhaust manifold - 29-36ft.lb
intake manifold - 13-19ft.lb
cylinder head - 53-63ft.lb
cam sprocket - 53-63ft.lb
cam bearing caps - 14ft.lb
8mm t-cover - 9ft.lb
10mm t-cover - 29ft.lb
oil strainer - 9ft.lb
oil pan - 9ft.lb
oil pump(top; short bolt w/seal) - 18ft.lb
oil pump(far left & far right; longer bolts) - 14ft.lb
oil pump(bottom; shorter bolts) - 9ft.lb
crank pulley - 120-130ft.lb
rod bearing - 40-47ft.lb
main bearing - 69-83ft.lb
flywheel - 80ft.lb
clutch pressure plate - 11-15ft.lb
belhousing-to-engine - 37-57ft.lb
master cylinder reservoir - 15-21ft.lb
Old Apr 25, 2012 | 10:52 AM
OrRunner's Avatar
This may help:
https://www.yotatech.com/forums/f114...gasket-182606/
Old Apr 25, 2012 | 11:10 AM
86carbPU's Avatar
thanks...
didn't realize heat shields for exhaust manifold fit between manifold & head mating surface...
other heat shield/shrowds mount up on side of manifold w/out gasket I haven't used one for years... I just keep those spark plug wires up & out of the way. thanks again.
cars-guy
Aug 16, 2020 06:59 AM
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
scottyg486
Jul 19, 2015 05:34 PM
Coreyr384
Jul 10, 2015 11:13 AM
