Pre 84 Trucks 1st gen pickups
electric fuel pump on my 82'
Old Oct 11, 2009 | 11:36 PM
ktown808's Avatar
ok so heres the deal took out the 22r and dropped in a 20r but now i need to wire a electric fuel pump was just wondering if anyone has done this and has some tips they would like to share, like what did you hook the pump up to accessory wire or whatever and another thing is it possible to remove the charcoal canister and run just one line from the tank so any tips or tricks will help thanks
Old Oct 12, 2009 | 03:27 AM
suncomb1's Avatar
Whatever electric pump you use you need to know its maximum amps. You need a relay and auto resetting circuit breaker sized larger then the max rating of the electric pump. I run a Mallory Model 110 using a relay and 15amp auto reset circuit breaker. The relay is energized when I turn on my ignition switch and the pump power comes directly from the battery through the circuit breaker. You could use a fuse if you prefer.
I moved the fuel tank canister from the firewall and installed it in the same place as the carb canister on the right fenderwell. I installed one hose with the jet from the canister to my intake manifold.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
