Pre 84 Trucks 1st gen pickups
Easy way to tell what your gear ratio is.
Old Aug 6, 2011 | 01:56 PM
mxstud1804's Avatar
I am wondering of the easiest way to tell what gear ratio my toyota has?
Old Aug 6, 2011 | 02:07 PM
SoCal4Running's Avatar
VIN # or data plate decoding.
Could also just search and find this https://www.yotatech.com/forums/f120...ratios-178636/
Old Aug 6, 2011 | 03:01 PM
Dutchbelly's Avatar
https://www.yotatech.com/forums/f116...osting-204178/
Incidentally that thread is on page one of the 96-95 truck tech page. There is a ton of info included on that page that should keep you busy.
Old Aug 6, 2011 | 04:40 PM
mxstud1804's Avatar
so when i ran the vin i found it had a gear ratio of 4.375, when i searched for any gears that matched it i had no luck. What is the deal???
Old Aug 6, 2011 | 04:45 PM
scuba's Avatar
4.38 is a rare ratio.
Old Aug 6, 2011 | 05:58 PM
85gijunk4x4's Avatar
never even knew 3.48 existed.
Old Aug 6, 2011 | 07:43 PM
scuba's Avatar
dyslexic much?
Old Aug 6, 2011 | 10:02 PM
holy cow, thanks for catchin that, scuba
Old Aug 11, 2011 | 05:53 PM
peow130's Avatar
4.37 is common in 79 axles. In fact, in 79' you could only get 4.37's.. 80' was 4.10s, 81' is 3.90's, then back to 4.10s after that.
Nobody sells this particular R/P combo because it's really not worth it. For the price of a new setup 3rd member you could get 4.56's, or even 4.38's.. And for REAL cheap you can find good 4.10 setups.
Now, to swap these into your near-stock 1st gen, would be decent. Granted you could get them at a reasonable price. They're better than 4.10's and 31's, and youre pretty close to 4.56's.
Old Sep 14, 2014 | 02:33 PM
1980lwb's Avatar
79-80 had 4.37. 81 had 3.90 then 82 had the 4.10-11 gear ratio.
RatOmeter
Oct 22, 2015 03:17 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Athansinis
Jul 27, 2015 08:38 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
razorman8669
Jul 12, 2015 12:13 PM
