Pre 84 Trucks 1st gen pickups
Early 1978 Toyota Pickup (Hilux) GM Conversion Wiring Question
Old Sep 9, 2019 | 09:06 AM
Dzhezzi's Avatar
Hello guys!
So after stinking up my neighborhood with a battery that was about to pop (smelled like rotten egg), and after doing some research I decided to just be done with the external regulator and convert over to an internally regulated alternator. I purchased a 12SI Delco 94 amp alternator and the bracket I need from LCE Performance. Now here is my issue, someone apparently already tried doing this and kind of cut a few of my wires that lead to the external regulator, I have no idea how I never noticed this. I have the 6-blade voltage regulator and need a bit of help to figure out if they did a god job or I need to redo some stuff. So it looks like they "spliced" or "jumped" four wires, the white/red wire to a green wire going to the alternator, a white/yellow (or yellow/white?) to a blue wire also going to the alternator.
Based on the wiring diagram I found out:
IG - White/Red
N - White/Light Blue
F - White/Green
E - White/Black
L - Yellow/White
B - White
Is there anymore work I need to do? Or is it just a matter of plug and play?
Thanks y'all!
Old Sep 9, 2019 | 09:23 AM
Dzhezzi's Avatar
So, I checked using a voltage tester to see what was HOT when the ignition switch was on. The White/red wire that was spliced to the green wire is HOT when the ignition switch is on and when the car is running. The yellow/white to the blue wire is HOT when the ignition switch is on, but once the car is running is OFF. Just some more info that might be worthwhile.
Dave80pickup
May 17, 2019 12:13 PM
KSA
May 30, 2017 07:13 PM
RedFive
Nov 18, 2014 06:03 AM
peow130
Nov 4, 2010 12:36 PM
Phssthpok
Sep 8, 2007 03:27 PM
