Pre 84 Trucks 1st gen pickups
Driveshaft for a W56 swaped 1st gen
Old Mar 23, 2009 | 07:34 AM
4banginRunner's Avatar
Just swapped a 22RE/W56 (out of a '87 4Runner) into a '79 Longbed pickup. The 3rds are stock '79 4cyl 4.38s.
I got the front driveshaft figured out, I'll be using an IFS shaft with the 79 "yoke" at the 3rd to match the patterns. 24" at ride height with room for compression and droop
Problem is with the rear shaft... I have 4 rear d/s's laying around and none fit, 1 from a 1st gen 4Runner, 1 from a 2nd gen 4Runner, 1 from the 79 and 1 from a '82 Longbed pickup (22R/L52?). The 4Runner's are to short and the 1st Gens are to long.
My question is; is there a Toyota drive shaft out there that will fit? Or is it inevitable that i need to get the long one shortened?
I would assume its cheaper to get a driveshaft shortened rather than lengthened? (removing, not adding material thus adding cost)
I need ~52" at ride height flange to flange.
And I do know about the different flange patterns...that does not bother me.
Old Mar 23, 2009 | 07:48 AM
4Crawler's Avatar
If this is for off-road use, I would pick wherever shaft is the best shape and have it built to the proper length with heavier wall tubing. The factory shafts are pretty thin wall material and get dinged up pretty easy if they make contact with anything.
Old Mar 23, 2009 | 07:53 AM
Its gunna be a 50/50 rig for now, offroad and a driver.
I hate to say it but I'm on a budget per say, I know so I'm hoping to find a junkyard shaft that's close.
A built shaft would be nice, but sounds like big bucks. From what i've heard around here $250+
Old Mar 23, 2009 | 08:31 AM
83's Avatar
83
Yeah they aren't cheap...
I don't know the answer to your question. I've always assumed that if you do that tranny swap you need to mod both d-shafts, so it's cool that you made the front one work. That's the more expensive one anyways.
Old Mar 23, 2009 | 04:16 PM
slacker's Avatar
shortening a stock shaft if your most echonomical choice ... about $40.00 last time I had it done ..
Old Mar 23, 2009 | 04:34 PM
I'm figuring I'll have to get it shortened...that price is something I can deal with, just gotta find a place that does it around here.
I'm still going to search at the junkyard tomorrow, but I'm doubtful.
Old Mar 23, 2009 | 04:45 PM
Plumbrbob's Avatar
I did the same swap 22R W-56 into a 79 long bed used the 79 to 87 shaft combo just to mated to match bolt patterns up front that worked good and then I got lucky in rear I did the same swap around but the difference is my donor shaft came out of a 87 xtracab SB I also installed the drive shaft backwards for bolt pattern reasons. flanges could have been swapped but I liked the fatter part of the d-shaft up higher
Problem: I had really bad wheel hop the drive shaft was 2" too long did not allow for compression. I installed TG rear springs and moved rear axle back 2" PERFECT! no wheel hop anymore
GL
Old Mar 28, 2009 | 09:42 AM
brooklee1000's Avatar
I don't know if this will work but I have considered the same mod for my '82 longbox(w56). I have the d-shaft from a shortbox, but am told that it will be to short. I was thinking that i might add a CV from a front shaft to it to make up the difference. You might try that if you have some extra CV's lying around to add to your short shaft. Might save you some money.
Old Mar 28, 2009 | 02:47 PM
gsb15's Avatar
a driveshaft from a lwb second gen pickup should be the right length, dont know about bolt pattern though
runnermedic
13
Sep 21, 2015 05:20 PM
icentropy
Sep 10, 2015 05:03 AM
May-39
Sep 6, 2015 01:05 PM
joeynational
Sep 5, 2015 01:54 PM
Badfish740
Sep 4, 2015 04:21 AM
