Pre 84 Trucks 1st gen pickups
clutch change?
Old Oct 15, 2006 | 08:06 PM
Sonofmayhem's Avatar
clutch change?
Ive been burning up my clutch because of my mad off road skills and the lack of a crawler box. So i was wondering how hard it is to change out a clutch on a 22r/20r hybrid, 4spd? should i get a centerforce? Im not worried about down time, but im just wondering.
Thanks
Old Oct 15, 2006 | 08:11 PM
Elton's Avatar
i did one on my 93 toyota pickup 22re took about 4 hours not that hard for clutchs i would go with this get the ceramic one
Old Oct 15, 2006 | 11:44 PM
hmmm. i like what i see, i saw a centerforce for like 260 on summit and then the heavy duty one for only 180 and you said about 4hrs eh? well i may just have to get one. Thanks, keep the replies comin.
Old Oct 17, 2006 | 09:57 PM
the_supernerd's Avatar
I just bought a clutch for my truck but have not installed it yet. The brand is Asco, which is supposed to be the same brand the factory uses but without the "TOYOTA" stamp on it. The dealer wanted over $300 for a clutch kit, but the Asco brand was about $120 for everything, including the pilot and throwout bearings. I figure the stock brand is good. I have about 176k on my truck and the clutch is starting to slip a little, but it has had some hard use. I learned how to drive on it when I was 9 years old and for about 90k my mom would always start off in second gear, even up hills.
Old Oct 18, 2006 | 09:42 PM
damn i just burned mine up from wheeling, im gonna buy a marlins right when i can then ill just put it in and pray
Old Oct 19, 2006 | 02:35 AM
AH64ID's Avatar
I got my CF DF for 235 on ebay, my last one 6 years ago was over 300 IIRC.
CF is a great clutch, and works very well. When I sold my other one it had alomst no wear after 30,000 miles.
If you can afford it look at a heavy flywheel, they make a huge difference.
Old Oct 19, 2006 | 03:33 AM
Intrepid's Avatar
If it is your first time doing a clutch and you are not incredibly mechanically inclined, plan for a whole day and plan for a long day. It is not hard, just time consuming. Rent a tranny jack, it will make your life much easier.
Old Oct 19, 2006 | 08:31 AM
sweet. ive done the timing chain, and stuff, plus this isnt my d.d so i should be good, thanks
Old Oct 25, 2006 | 03:41 AM
dilvidor's Avatar
Clutch is easy. Less than a day. I would also suggest a tranny jack as Intrepid said. I did mine on a 2 ton floor jack with the 2" plate and the tranny fell pff a couple times trying to get it lined up (not fun). Make sure you get the allignment tool or an old input shaft to get the plate lined up or you're in for a long long day.
Old Oct 25, 2006 | 07:01 AM
Where can i rent a tranny jack??? pepboys? vatozone? checker? aap?
smthwsn357
May 1, 2024 07:28 AM
Dieselmann
Feb 19, 2019 02:57 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
the1998sr5
Jul 16, 2015 06:20 AM
