Pre 84 Trucks 1st gen pickups
charging issue
Old Apr 12, 2012 | 11:00 AM
tazz76's Avatar
charging issue
To start off its a 83 4x4 just put a remaned alternator on it but yet if she sets for a day it will be dead. Checked to make sure i didnt leave the lights on and i didnt. Have no idea what would be killing the battery any ideas would be greatly appreciated. But it is a good way to work out roll starting it by yourself on a flat driveway
Old Apr 12, 2012 | 12:09 PM
kawazx636's Avatar
When you get a new alternator, it's best to get a new battery or make sure that your old battery is putting out good amperage and is well charged. The reason being is that the alternator "works harder" to recharge that dead battery. Get the battery tested and/or replaced. That will probably solve your problems.
Old Apr 12, 2012 | 12:39 PM
tazz76's Avatar
I forgot to add i put a new battery when i did the alternator
Old Apr 12, 2012 | 12:49 PM
jswizz's Avatar
Just wondering if you've got any toggles that may be left on or maybe something else is draining it . Good Luck !
Old Apr 12, 2012 | 02:17 PM
tazz76's Avatar
No theres no toggles i thought about putting in one of those battery kill switches to c if that would help. Could i possibly be the ground wire to my battery not grounded any more so the circuits not complete for it to charge up
Old Apr 13, 2012 | 09:53 AM
Bingle's Avatar
I have a similar issue in mine. Takes a few days for mine to "trickle drain" the bat. I think I just need to go around and clean up all the grounds ect. Curious to see what you find on yours.
Old Apr 13, 2012 | 06:13 PM
Pumpkinyota's Avatar
Some things to check:
Are your battery terminals making good contact?
Is your battery ground / engine strap in good shape and making good contact with the block?
Get a multimeter, test bettery voltage with vehicle off, and with vehicle running. Are you charging?
How is your belt tension? The alternator belt can be difficult to properly tension. I use a long (24") pry-bar to pull out/tension the alternator, and I also double-nut the bolt that threads into the alternator at the top.
How is your voltage regulator doing?
Is the charge cable making good contact with your alternator, and with your battery?
Good luck!
Old Apr 13, 2012 | 07:27 PM
jswizz's Avatar
about the neg battery ground it may definatly help to have a good solid connection . " the guy at the shop told me it would be a better ground mounting mine on the block" , and its been working fine except when I leave a toggle on .
Old May 3, 2012 | 07:07 PM
tazz76's Avatar
thanks for the info alternator is tight grounds r cleaned got the alt. tested to make sure it was working and it is. now wheres the voltage regulator cause if its close to the alternator its probably killed. because my radiator hose blew out and soaked the old alt. which killed it
Old May 3, 2012 | 07:30 PM
Voltage regulator is on the drivers side inner fender. It will be a black or gold box secured to the inner with two 12 mil bolts. Your year should have a 6 pin oval shaped wiring harness connector.
Old May 6, 2012 | 05:01 PM
tazz76's Avatar
thanks for the info changed the voltage regulator and shes charging up and has held it for 2 days now so i believe its got it
Old May 6, 2012 | 07:25 PM
Perfect, congrats! Glad it wasn't a wiring gremlin
Old May 7, 2012 | 05:36 PM
tazz76's Avatar
now only if it stays that way whenever i tear the motor down and rebuild it. i do however have a wiring gremlin in my rear turn signals the flash in uni-sen now mater which way i go to turn
80Truck
Oct 12, 2025 07:25 PM
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
mr_manny
Jul 31, 2015 10:39 AM
