Pre 84 Trucks 1st gen pickups
Carbs... anyone running this stuff
Old Jun 11, 2007 | 06:02 AM
4stAir's Avatar
i am curious to see what you all are running for aftermarket carbs...
i know webers are popular, and i see holley has a truck avenger carb out for yotas. Anyone have any opinions what would be a better carb for a trail rig. i have no engine wiring harness in my truck and emissions isnt an issue in my state for a vehicle as old as mine.
just curious as to what you guys recommend, and how hard is it to wire an electric choke?
Old Jun 11, 2007 | 06:32 AM
86toysr5's Avatar
i dont have a carbed truck anymore but i had aisan stock carb on my but theres a buy that has a 84 around here and he has a holley and said once he got it tuned right it runs awesome
Old Jun 11, 2007 | 10:31 AM
4Rocker's Avatar
I have a Weber 38/38 that sucks gas, but once tuned it runs pretty well.
The electric choke on the weber just requires a hot ignition wire to work (same with the fuel cutoff solenoid if equipped).
Old Jun 11, 2007 | 11:06 AM
INFINITY's Avatar
i am going to be getting the 32/36 weber with the manual choke, withthe rejet kit (high altitude). i think anything will be better than the old carb that is on there now.
Old Jun 11, 2007 | 12:04 PM
4stAir's Avatar
ok guys so either way i should be ok.... i saw a bunch of webers on ebay today so i guess i will look that route.
the main reason i am doing this is i have no wiring harness, i am tryin to eliminate any need for all those goofy vacuum sensors on passengers side fender.
i guess a d.u.i. would the next step in ensuring it will run well.
thanks for the help guys
Old Jun 24, 2007 | 11:44 AM
Bowmens's Avatar
weber
I just installed a rebuilt weber carb on my 1978 toyota. All that is left is hooking up the vacume lines... Where can I find a diagram for some help...
Old Jun 25, 2007 | 10:24 AM
4Rocker's Avatar
The only vacuum line you should need with a Weber carb is the vacuum advance line that connects from the port on the base of the carb to the vacuum advance port on the distributor.
Old Jun 25, 2007 | 10:59 AM
4stAir's Avatar
this is true....
Old Jun 26, 2007 | 06:14 PM
Yota Tony's Avatar
That's all you need with any carb on the 22R.
I'm running a stock Aisin carb on my truck with a few mods. Why mess with a good thing? The way it is set up the truck can run upside down.
Old Jun 30, 2007 | 10:25 PM
Island_Yota's Avatar
I tuned up my Aisan today, Ive never seen main jets so clogged in my life, it took some serious effort to get those things unclogged and literally nothing on the carb was working so I finally decided to drop $45 on a kit, funny part is it was running before off the power valve only! Turns out its a stock Aisan off a 20R(my motor is a 22R) but no big deal it runs great now.
Heres a vid of it while the power valve was still stuck open (flooded + running reallly rich) its fixed now though..
http://www.youtube.com/watch?v=EhsI7-a6F6s
and another:
http://www.youtube.com/watch?v=OTT9bbhcwoo
oldirtydirt
Feb 23, 2020 09:30 AM
Regency
20
Jan 3, 2020 07:43 PM
Doug4320
Mar 24, 2018 10:11 PM
DrZero
Jul 13, 2015 09:59 AM
akaphilly
Jul 9, 2015 02:34 PM
